05-18-2009, 01:38 PM   #1 (permalink)
gentz
insearch of another part. power steering braket.
ok my power steering pump is on and working just that it wobbles alot.. seems another bracket should hold it to the engine. anyone have a diagram or the bracket, or know where i can get it?
gentz is offline   Reply With Quote
05-18-2009, 07:46 PM   #2 (permalink)
ShotRod64
Re: 1962 galaxie 500 neutral/reverse switch.
I don't know if '62 is the same as a '64 or not. This is what my bracket looks like and it bolts to the front of the pump. Yours might be the other style that has the bracket on the back maybe? I'm not familiar with the other but here's a pic of what mine looks like.
05-18-2009, 07:50 PM   #3 (permalink)
gentz
mine is just like that ...hmm strange so it doesn't take a rear bracket? mine seems to wobble a bit when running. and i was under the impression that another rear bracket was needed
05-18-2009, 07:51 PM   #4 (permalink)
gentz
Hopefully i will get to the point you are at with them nicely painted. Looks nice
05-18-2009, 07:58 PM   #5 (permalink)
ShotRod64
Oops! put that in the wrong thread didn't I!! LOL
Never had anything else hooked to mine. There is a bolt sticking out the back but seems like at some point when I asked about it that it had something to do with it might of been in an AC car.
Mine doesn't wobble, do you think you might have the bolt too tight or does it appear to wobble because the pulley is bent or something?
That is one of the few remaining pieces that still has most all of it's paint. It was done a few years ago and now the water pump is peeling cause I must not of got it clean enough when I replace it and the fuel pump is all peeling from too many gas spills on it and time. But it was nice to start with. Well to me anyway.
My valve covers, Generator, radiator and the power steering are about the only things that are pretty much still in good condition. Oh and the froggie fan guard.
I still have miles to go on a lot of other things though, just happened that I changed engines before I got far on anything else.
05-18-2009, 08:00 PM   #6 (permalink)
gentz
hehehe thats ok...yea im gonna check it out tomorrow... maybe my bracket is loose .. gonna adjust the belt and see. also hope someone knows where i can find the safety neutra switch and reverse....or i may have to modify and try to repair the original....
05-18-2009, 08:32 PM   #7 (permalink)
ShotRod64
I moved the posts to this thread where it should be but did reply on the switch in the right place! lol
05-18-2009, 08:47 PM   #8 (permalink)
gbic1
Re: insearch of another part. power steering braket.
Check you pulley to make sure it is not bent. Remove belt and look at it, Try another belt. Maybe it has a bad spot. I have seen it. Mine does not wobble.
1964 Galaxie 428
1966 Mustang 302
1967 Cougar 390
1968 F250 Camper Special 390
05-18-2009, 08:50 PM   #9 (permalink)
Domino
My 62 only has the one bracket. The bolts that hold it to the water pump have big, thick washers on them. They would add some stability. The parts car 62 has another bracket behind it that is part of the A/C setup.
1962 Galaxie 500 2 door sedan(62A) http://www.cardomain.com/ride/3091676
The car is named Albert(Big Al, not Big Gal!) ¨Built not Bought¨
Domino is offline   Reply With Quote
05-18-2009, 09:06 PM   #10 (permalink)
gentz
yea will check and see.. If i put my hand on the reservoir while running it just doesnt wobble...and doesn't feel as the pulley is bent, may be a bad belt or loose..ill check it tomorrow morning.
change manual steering to power steering earlytime1969 Mustang Pages (1965-1973) 6 04-28-2008 03:14 PM
power steering pump fittings for a mustang II power rack gtnrb71 All Ford Techboard 1 06-10-2004 12:10 PM
alt braket My864x4 All Ford Techboard 1 01-26-2004 02:44 PM
C6 braket fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!I did it!!!!!!!!!!!!!!!! wildosvt01_OLD All Ford Techboard 3 10-14-2002 05:59 PM
Power Steering, ATF or "Power Steering Fluid" thecougarguy All Ford Techboard 8 02-26-2002 06:45 AM
