06-12-2009, 01:28 PM   #11 (permalink)
gentz
Re: Cruise o matic adjustments
well been working t this most week.. Maybe its due to the short times i work on it i may be missing something.. Ok my car has the 3 speed cruise o matic, the shifter has at the very far righ a L then green dot, then just a dot. I notice that in the green dot it starts in 1st and in the white dot it seems to start in 2nd. i tried to drive it in the green dot and it takes a while to shift to 2nd. I did check the modulator and it does have a little screw for adjustment where the vacuum hose goes but where should it be? the screw is almost all the way out. well i will play with this a little more today or i may just throw in a new modulator to see if indeed it is defective, it doesnt leak any tranny fluid to the vacuum hose but it may still be bad. I will also pull out the governor later today , just that it seems as if i have to remove the cross member for the tranny to get to the cover.
If it aint Broke lets modify it!
1962 Ford Galaxie 500, cruise o matic, 292.
gentz is offline   Reply With Quote
06-12-2009, 07:05 PM   #12 (permalink)
ShotRod64
I'd just put a new one on there and go from there. But if you want, adjust and drive and adjust according to how it shifted and see which way you need to go with it. Might be the culprit.
You can use a swivel and a small ratchet and extension to get to those bolts by the cross member. Little tricky and takes a bit more time but it is doable.
06-12-2009, 07:32 PM   #13 (permalink)
gentz
thanks i was under there and noticed it wasnt as hard as it looked. will get on it tomorrow.
06-25-2009, 03:52 AM   #14 (permalink)
lgh1157
Gentz, how is it going, any news ?
PANEL BEATERS C.C - WE GOT GREASE UNDER OUR NAILS, NOT IN OUR HAIR
lgh1157 is offline   Reply With Quote
06-25-2009, 12:10 PM   #15 (permalink)
gentz
well i replaced the modulator, removed the governor, and cleaned it but there is something strange we cannot id the governor and cannot find if it takes a spring or not. I know this is where y funny shifting is coming from but cannot find any info...check my post of pictures of a governor... the pics are there....
06-25-2009, 08:07 PM   #16 (permalink)
lgh1157
is the governor hard to remove ?
06-25-2009, 08:50 PM   #17 (permalink)
gentz
the governor is easy to remove have removed it several times...
07-02-2009, 08:24 PM   #18 (permalink)
oneputtster
Can you describe the push rod in the modulator and how does it attach?
Putts drives a 1965 Galaxie 500 4dr. 352 4V AC PS PDrumB cruis-o-matic.
oneputtster is offline   Reply With Quote
07-02-2009, 08:55 PM   #19 (permalink)
gentz
i will pull it out tomorrow as i already removed the valve body and unstuck all the valves but it seems my governor is acting up still will pull out the modulator and governor in the morning and post pics...
What's a Cruise-o-matic? RickRacer Fairlane Pages 23 12-27-2007 06:31 PM
cruise o matic or ford o matic? stickshift Galaxie Pages 1 11-09-2007 10:27 PM
Cruise-o-matic or C6?How can you tell? MauriSSio Galaxie Pages 7 03-25-2006 08:04 AM
Ford-O-Matic & Cruise-O-Matic Reading Material Galaxie_406 Galaxie Pages 1 10-17-2005 10:36 PM
will a 302 fit a cruise-o-matic? Vincent62 Galaxie Pages 4 02-14-2003 02:53 AM
