Originally Posted by blueoval67
This may be a day late but the starter should drop out without removing the mainfold as was said before. I just did this on a 62 g code last month. You have to drop the idler arm down and your all set. Removing the two bolts in the frame should get you there.
All I can say is..... U R DA MAN! After laying under the car looking at the
under bolt on cylinder 3 for a few minutes today, I decided to do it your
way. WALAH! I did have to disconnect the exhaust pipe from the header
but that was no big deal. All of the teeth we gone off of the starter. There
was even a chunk of 4 teeth sitting in the bell housing.
Thanks for every ones input!
