07-03-2009, 01:12 PM   #1 (permalink)
ShotRod64
Ever Notice how hoses don't last?
Used to be hoses would last 20 yrs or more. They might get hard and a little cracking on the outside but still didn't leak even though they needed replacing.
I mention this because it was only 3 or 4 yrs ago that I changed the piece of hose that goes from the hard line to the gas tank and now it's leaking with a big crack in it. I was wondering why I would smell gas back there and looked down in to see if the filler neck was leaking as it was broke loose when I got munched and had it repaired. Didn't see nothin. Never saw any puddles either. But then I rarely have a full tank of gas so it must of leaked from the sloshing of the gas when I'd park the car or something and then I would smell it. Rest of the time was too low to leak even with sloshing.
Guess they probably took the good stuff out of the rubber or it's this modern gasoline that causes them to deteriorate quickly.
Deb
Always be yourself, because the people that matter don't mind, and the ones who mind, don't matter.
www.so-calgalaxies.com
www.galaxiesnw.com
07-03-2009, 02:06 PM   #2 (permalink)
75Squire
Re: Ever Notice how hoses don't last?
Probably a combination of both.
75Squire is offline   Reply With Quote
07-03-2009, 02:24 PM   #3 (permalink)
ShotRod64
Wonder what level of fuel it is at the hose going into the tank? lol It's draining now from the hose leak. I have somewhere between 1/2 and 3/4 tank in there.
Did get the new speedo cable in though. Just have to put the screws back in the dash cluster. Another case of only needing to do 2 things. Although I knew the speedo would be a royal pain as it was last time. With the swingaway it's easier to disconnect the end on the tranny and pull the cluster out to get to it.
07-03-2009, 02:44 PM   #4 (permalink)
CaptVirgilHilts
Chinese rubber.... that's why there is a billion of them!
I use fuel injection hose and clamps now on everything like that. Way tougher and although more expensive it's only a few inches so one foot of it goes a long way for a few more dollars.
Stu
1967 Mustang Coupe
07-03-2009, 04:44 PM   #5 (permalink)
oneputtster
Good one, Cappy!
Putts drives a 1965 Galaxie 500 4dr. 352 4V AC PS PDrumB cruis-o-matic.
oneputtster is offline   Reply With Quote
07-03-2009, 05:03 PM   #6 (permalink)
ShotRod64
I'll have to remember that!
07-05-2009, 04:19 PM   #7 (permalink)
63ford406
It's mostly the "new gas". They have new hose, I don't remember the SAE number for it. Got to ask for it or they will give you the old stuff.
Ford Galaxie Club of America #665
So-Cal Galaxies
63ford406 is offline   Reply With Quote
07-05-2009, 08:19 PM   #8 (permalink)
ShotRod64
Thanks I'll have to remember to ask. Don't want to be doing that every couple years or so. Which reminds me, maybe I should toss in my extra piece for my drive to Oregon tomorrow since the fuel pump end was changed around the same time.
Deb
07-05-2009, 11:41 PM   #9 (permalink)
71hotrodpinto
Yep its the gas. The content of ethenol or whatever makes it cleaner ive heard is the issue. The gas these days also goes bad faster then ever.
If you go to kragen they have some Goodyear fuel injection hose. It has a blue liner in it. That stuff is going to stand up to the gas alot better even though you dont need the high pressure rating.
Dont run though, its about $6 a foot.....
Life long project. No it wont ever end....
07-06-2009, 07:06 AM   #10 (permalink)
ShotRod64
The stuff I got evidently for the fuel pump hoses is dif. Says fuel/emmissions on it and 50 psi. But when I'm rich and famous and need another chunk of hose I'll have to get it. Save money in the long run I suppose when not having to change it every year.
Did anybody notice... FEandGoingBroke The Garage 5 11-20-2004 05:52 PM
Just notice something.. New Oil Pan bud168 All Ford Techboard 4 07-02-2004 04:26 AM
Did ya ever notice... ZRX61 The Garage 11 02-19-2004 07:15 PM
urgent notice ;) MonsterMach The Garage 0 03-24-2003 08:34 PM
Ever notice????? gchero351 All Ford Techboard 5 08-07-2002 09:34 PM
