10-12-2009, 08:27 PM   #11 (permalink)
Meteor800
Re: Timing jumped?
Update..
I took the valve covers off, ran a compression test, 4 cylinders had ZERO compression.
So we took the heads off, found burned valves.
Did a valve job, ended up being $600, not including the gaskets. In total, it was $800 to repair, not to mention having the car towed to the Auto Hobby Shop on base.
After we put it back together, I tried to set the timing but the pointer is missing! Instead, I just advanced the timing until the engine starting pinging, then retarded it just enough to get it to run without knocking.
Long story short, the 800 runs better than she ever has in the year I've owned her. Now she feels like she has power!
1961 Mercury Meteor 800 4-Dr Hardtop, "Lucille" (352, 2V, in progress)
1962 Mercury Meteor S-33 2-Dr Sedan (260 V8, daily driver)
Meteor800 is offline   Reply With Quote
10-13-2009, 08:41 AM   #12 (permalink)
Re: Timing jumped?
That's awesome that you're on the road again!
I do recommend that you make a self pointer in order to fully know your timing to prevent any future issues...
Honor!
10-24-2009, 03:21 AM   #13 (permalink)
Meteor800
Re: Timing jumped?
I have to replace my water pump next month, as well as have my radiator rodded/recored, so maybe I'll get a timing cover with a pointer already on it, and just install it since I'll have all that room to work while the shop has my radiator.
Do you think there would be a problem with me using a timing cover from a later model FE? I have a friend whos sitting on a 390 from a 62 Galaxie, said I could strip parts from it if I wanted.
10-24-2009, 11:04 AM   #14 (permalink)
Re: Timing jumped?
Not a problem at all. Early on the 352 and the 390 shared the same timing marks and pointer.
Honor!
Looks like he jumped the last fence...and made the Great Escape RIP CaptVirgilHilts The Garage 2 10-12-2007 12:50 AM
Just jumped on the BIGS bandwagon! Bossman The Garage 16 06-16-2005 08:52 PM
what are the symtoms of a jumped timeing chain Foxx69 All Ford Techboard 1 06-12-2005 06:59 PM
I just got jumped............ MightyMach The Garage 16 09-20-2004 11:47 PM
Jumped timing chain? tateg All Ford Techboard 8 11-20-2002 12:51 AM
