09-25-2009, 12:43 PM   #1 (permalink)
Tone Deaf Guru
390 motor mounts for a '64 Galaxie
Hi,
I was wondering what motor mounts folks recommend or use when installing a 390 in a '64Galaxie. I found some at the Crites web site and was wondering if those are ok, or if anyone knew of something (maybe poly) that would a better fit. The engine is not stock.
Thanks in advance,
TDG
Tone Deaf Guru is offline   Reply With Quote
09-25-2009, 03:20 PM   #2 (permalink)
galaxie
Re: 390 motor mounts for a '64 Galaxie
Originally Posted by Tone Deaf Guru View Post
Hi,
Thanks in advance,
TDG
I have some from Crites in my 64. My motor is now a 417 FE. Tripower, Edelbrock Alm heads, roller motor, Tremec, pleanty of power. No issues. A friend of mine with the same set up had his motor moving too much. He simply chained the left side of his motor to the frame. $2 fix.
I dont have much movement at all from my mounts, however I do not launch on slicks. Are you running a full slick?
59,60,64,65,66 Galaxies Y-blocks to FE Strokers
87, 93 Mustangs Stock & 331
Pittsburgh PA
http://threerivers.galaxieclub.com/
galaxie is offline   Reply With Quote
09-25-2009, 06:07 PM   #3 (permalink)
coosbaylumber
Back when, I mounted up a 427 straight oiler into an XL with six duece carbs with common rubber/steel mounts. As I remember there was a righthand and lefthand side.
Wm.
Old Ford owner
09-26-2009, 03:16 AM   #4 (permalink)
Tone Deaf Guru
Talking Re: 390 motor mounts for a '64 Galaxie
Thanks Guys, I'll just give them a call. I wasn't sure if these would be ok, or if there was something else folks prefered, or a mod.
Thanks again,
TDG
Solid motor-mounts for a 1965 (63) Galaxie? AnderssonsGalaxie Galaxie Pages 10 09-03-2006 05:05 AM
67 galaxie motor mounts tbolt390 Galaxie Pages 2 05-02-2006 02:55 PM
Motor mounts for 460 into a \'68... Will \'69 429 mounts work? adgdghr123 Galaxie Pages 2 09-07-2005 08:38 PM
FE Motor Mounts (pic) Effie All Ford Techboard 1 02-14-2003 12:04 PM
460 in '65-68 Galaxie using '69 429 motor mounts? bdraeger Galaxie Pages 0 09-08-2002 04:13 AM
