10-17-2009, 10:54 AM   #31 (permalink)
tomrzk
Re: Progress on The New 66
Well I dont know what the problem is here I replaced the fuel pump now Im getting fuel to the carb. I repleced the coil now I have spark. I replaced the starter syliniod, ignition switch(autozone) and tumbler and I still cant get it to crank from inside. I do get the oil light to lite up when I turn the key but thats it for now.
1966 LTD 390
If It Aint Broke...Modify it! But its broke so Im fixing it!!
tomrzk is offline   Reply With Quote
10-17-2009, 11:04 AM   #32 (permalink)
fordman460
Posts: n/a
Time to get a volt-ohm meter and find out where the power stops!
10-17-2009, 11:19 AM   #33 (permalink)
Rich27028
when you turn the key to start --does the solenoid click --??
66 galaxie 352 -PS-PB-
Rich27028 is offline   Reply With Quote
10-17-2009, 11:48 AM   #34 (permalink)
tomrzk
Well I cant hear it myself Because with this new ign switch it clicks pretty loud when I turn the key
1966 LTD 390
10-18-2009, 11:28 AM   #35 (permalink)
tomrzk
Ok Im just confused!!!! I was playing with the car today and I broke a wire that goes to the syliniod and whe I got it together the car was on the "on" position and when I went to coneect the wire the car started cranking when I touched the wire to the post. I had to pull the neg cable of to sotp it. It would stop when I turned the key back either. Also when I saw that the oil light was staying on even when the key was off. Any Idea What is wired wrong?
1966 LTD 390
10-23-2009, 01:32 PM   #36 (permalink)
tomrzk
I just check the wires at the ignition switch and all the wires light up on the "on" position except the red with blue strip and when I turn it to the start pos. all the wires exept the shaft on back light up. When I go out under the hood and have someone turn it to start, the red and blue doesnt light up on the syliniod. So from the syliniod to the fire wall That red and blue strip wire there is no power. but there is power to that wire at the switch. So what Im going to do is trace the rest of the wires from the switch through out the harness and start replacing wires! Im getting some progress here!!
1966 LTD 390
11-16-2009, 11:16 PM   #37 (permalink)
tomrzk
Ok heres the scoop...Im still having all kinds of problems. I put a holley 600 on the car and it was running better. Much less smoke but still running rough! I started pulling plugs while the motor was running and heres what happened I pulled wire 1 and no difference in sound, wire 2- rpms went up wire 3- rpm went up plug 4-no difference plug 5 I dont think much of a difference plug 6 rpms went up plug 7- stumbled plug 8 stumbled. Now I replaced the wires and it ran better but still rough. I replaced the cap and rotor now the car doesnt want to run it will start up but dies right away. I replaced it with a borg warner cap and rotor. So I think Im going to take the cap and rotor back or atleast swap the old cap back on.
My question is is the firing to me it sounds like the firing order is off but the wires are corect ive checked different books and they all give the same order. Another thing is when the cars running I get smoke comming through where the spark plug seats and the plugs are getting soaked!
Any pointers at all?
1966 LTD 390
11-17-2009, 11:22 AM   #38 (permalink)
Ggrahn
Compression test. Replace spark plugs.
Gary
66 Custom 500 390 2v
Ggrahn is offline   Reply With Quote
11-17-2009, 11:43 AM   #39 (permalink)
Rich27028
take a commpression test and post the numbers here-- be sure to number the cyls --1 thru 8 so we can see what each cyl is doing beside each other
11-17-2009, 12:06 PM   #40 (permalink)
tomrzk
Ok when doing a test should I pull the fuel pump off also? So I dont have fuel going inside the cylinders or do I need the fuel in there?
1966 LTD 390
my s-l-o-w progress sleepysal Galaxie Pages 14 04-17-2006 12:02 PM
A Little Progress Murff Falcon Pages 3 02-28-2006 09:41 PM
More progress... deleted3 The Garage 6 03-29-2004 04:47 PM
More progress deleted2 The Garage 5 03-07-2004 12:14 AM
Progress on my 331 mstngjoe The Garage 17 05-16-2003 07:53 AM
