10-17-2009, 05:38 PM   #11 (permalink)
Rich27028
Re: not sure what we have here
look at the block -back by the starter-- just under the head- theres a little raised boss-- --c7mea is a block number- 390
dont know about the heads-- did you get this number from between the valves under the rocker shaft??
66 galaxie 352 -PS-PB-
Rich27028 is offline   Reply With Quote
10-17-2009, 05:39 PM   #12 (permalink)
aml390
Originally Posted by r.n.r.racing View Post
Sorry, can't tell you anything other than they are '67 heads. All my books are at the garage where I store my car which is 40 miles from here. Without looking it up, I am not much good with casting and part numbers.
thanks man ---when you get round that way maybe you can have a look at that.getting alot of dif info AL
aml390 is offline   Reply With Quote
10-17-2009, 10:07 PM   #13 (permalink)
gbeeler
I took a 360 and built a 6000 rpm 431 stroker. Edelbrock heads and intake with Scat crank and roller everything. Should be around 500 hp according to the builder and the motor is VERY streetable. 2200 stall might be a little low for the size of the car but she runs respectible for such a large girl. A fairlane shouldn't have that problem. Heads and exhaust are the two biggest power killers on the FE motor. Drop the intake for an aluminum version and you drop 50#, or atleast it feels like it. I've built an FE stroker and a 385series BBF stroker. Both are expensive if you buy all the parts new. FE ran around 7k a few years ago. Good luck!
64 Galaxie 500 XL Hardtop (constantly morphing)
FE 431 Stroker, C-6
64 Galaxie 514 XL Convertible (WIP)
514 Stroker, AOD
gbeeler is offline   Reply With Quote
10-18-2009, 01:53 PM   #14 (permalink)
fordman460
Posts: n/a
As gbeeler suggests, stroker is the way to go. In that case all you should use, of the original parts, is the block (and maybe some bolts). Stroker kits, heads, and intakes are available that will out perform any of the stock stuff that will fit your bore.
10-18-2009, 07:55 PM   #15 (permalink)
aml390
We found the numbers on the heads today. C8AE-H---In searching the internet and here Im getting alot of different words on these.A caouple different references say that the C7ME-A on the block means its a 428,We checked the bore on the engine today and I was able to just slip 4.05 in there.The rods are about 6.5 inches long and the stroke(as best as I could measure it was around 3 and 3/4".Others here and elsewhere are sfaying the c7mea doesnt mean a whole lot. Other than it is a 67 for sure.
As for the numbers on the heads C8AE-H Im hearing its 1968 and 427 from one place on internet.Then Ive also heard that those #'s dont real;ly mean anything other than they are 1968 heads.Does anything mean anything on these other than the year?(Blocks or heads?)
10-18-2009, 08:01 PM   #16 (permalink)
aml390
Originally Posted by aml390 View Post
know anything about the C7 MEA on the heads? good ones?
Mistaken---it was c7mea on block----we found the head # today c8ae-h
10-18-2009, 09:25 PM   #17 (permalink)
Ausgal67
C8AE-H heads are for 1968 360/390/428 motor with thermactor, these would have 67-70cc chamber.
No problems there.
If the smog system has been disconnected there will be small plugs on the top of each exhaust outlet.
David.
67 Galaxie 2 door Fastback
67 GTA390 Mustang
BF MK2 XR6 Ute
Ausgal67 is offline   Reply With Quote
10-19-2009, 07:22 AM   #18 (permalink)
64Ragtop
Here is a web site that says the C7MEA is a 330 mediun duty truck block or a 428 police intercepter cobra jet!
Ford FE Engine Block Casting Numbers - FORDification.com
As far as the heads go there are only a few differences but most of the common heads are on everything from the 352 to the 428. I believe the C4AE heads and the C8AE heads are the most wanted stock heads but I'm sure others will disagree.
64Ragtop is offline   Reply With Quote
10-20-2009, 08:57 PM   #19 (permalink)
aml390
The heads are C8AE-H---I looked at the site and its saying only one choice for those numbers and that is '68 427-----anyone on this?
10-20-2009, 09:04 PM   #20 (permalink)
How many bolt holes are those heads sporting for the exhaust manifolds???
Honor!
