<LTDs are special, and the fact that its a two door is even better (no offense fordman
Me or 460? There's two of us hanging out here.
My LTD is also a 2dr. I almost considered a 4dr because I was having a hard time finding a good 2dr. Nothing against em here either.
There is a 4A fuse in the fuse panel in the glove compartment for the instrument lights. It's the 3rd one down above the two that are side by side. Check that fuse and see if its blown and if it is replace it. If blows again pull the fuse and turn the lights on. If you have a multi-meter one side should show 12V and the other 0V (with the fuse out or a blown fuse in) check the side with 0V and see if there is continuity to ground and if so you have a short.
Greg
