10-22-2009, 05:39 AM   #1 (permalink)
oneputtster
How many petcocks in a block?
Under my 352 there is a drain that works just like the petcock in a radiator, but it is on the block, driver's side. I like it, but I'm wondering how many there are?
Putts drives a 1965 Galaxie 500 4dr. 352 4V AC PS PDrumB cruis-o-matic.
oneputtster is offline   Reply With Quote
10-22-2009, 06:37 AM   #2 (permalink)
Rich27028
Re: How many petcocks in a block?
none -- btw sombody added it --their not factory installed--
66 galaxie 352 -PS-PB-
Rich27028 is offline   Reply With Quote
10-22-2009, 06:57 AM   #3 (permalink)
64Ragtop
Never seen one on a block. Must of been added to drain the water when in storage in a cold state.IMO!
64Ragtop is offline   Reply With Quote
10-22-2009, 07:06 AM   #4 (permalink)
I've had them on several engines, and I personally add them to my rebuilds to ease water drainage for swapping head gaskets and intakes.
Honor!
10-22-2009, 07:55 AM   #5 (permalink)
coosbaylumber
On my big engines, there were two. A sort of brass 3/8" pipe thread plug, one each side, near to engine mount.
These were not easy to remove either. No leaks once out, as the block goo tended to settle there. Ran a wire inside the the dark water and then the rust flowed out.
We discussed methods to remove a good year ago here. I think 406 headed it all off.
Wm.
Old Ford owner
10-22-2009, 08:24 AM   #6 (permalink)
Rich27028
the plugs are there --but the petcocks he ask about was never a factory feature-- some one put them in later
10-22-2009, 10:07 AM   #7 (permalink)
ShotRod64
I never let my pets play under the hood... as for those plugs, there is one on each side. A petcock would be a good addition though if there a person did mostly highway driving. I'm not so sure i'd want them on a car spends a lot of time on gravel roads like mine used to.
10-23-2009, 05:25 AM   #8 (permalink)
oneputtster
Thanks all for the responses. I've had the radiator rodded sp this seems like a good time to be thorough with the block water. I'll look on the pasenger side for another one.
10-23-2009, 07:01 AM   #9 (permalink)
Rich27028
it would do you better if you had it back flushed [ the block]-- its a connection that uses water and air pressure to blow all the old core sand and crud out of the block-it is done with the engine right in the car-- takes about half an hour- and any radiator shop can do it -- - my suggestion - unhook the hoses going to the heator core-- they dont like that high pressure-- - -it will keep you clean rodded radiator clean- and it will most defnatly run cooler--
for your info- i at one time owned a radiator shop- i just heard that my old radiator man had died -- heart attact--stop smokeing it will kill ya -
10-23-2009, 07:37 AM   #10 (permalink)
Heater core can handle more pressure than the radiator. But if it's as old as the car, I backup Rich about taking it out of the equation...
Honor!
Big block radiator with small block 1968 9t3lightning Galaxie Pages 1 10-28-2007 03:32 PM
New 8.20 sbf boss racing block vs worlds block stoker All Ford Techboard 35 12-06-2006 10:23 PM
E7TE small block heads on C8OE block Kman All Ford Techboard 6 06-08-2006 10:40 AM
351W lightning block vs standard roller block mustangzrule All Ford Techboard 6 08-27-2004 09:53 PM
Anyone use a big block fuel pump in a small block? mc All Ford Techboard 4 04-21-2003 03:34 AM
