10-23-2009, 04:33 PM   #1 (permalink)
Nickas
289 stumbling at part throttle.
This started two days ago. On the way to work I noticed right before I shift, in both first and second gear the engine would lose power and sort of begin stumbling. Same after work. So today on the way home, I kind of held it there instead of shifting to listen. Hoping to troubleshoot this thing or just put it out of it's misery. The stumble began to creep farther down the rpm range. Next thing I know, I'm pulling off with almost no power. Than she dies. Tried to crank it. Nothing. Pop the hood and check for fuel at the carb by working the linkage and I'm getting a mist more than a spray. Ten minutes later, she cranks right up and pulls hard thru the rpm range, no stumble. What gives? What do you guys and gals think. Where to start looking? This is my daily driver and I need to repair it by monday for work. I'm thinking it's fuel related, but am looking for opinions and trouble shooting tips. Thanks in advance. By the way, she's a stock 289, 3 spd trans, and 2 barrel stock carb. The ignition all looked okay a month or two ago, but I have noticed the fuel pump ticking lately.
65' Galaxie 500 Fastback. Custom rusted torque boxes & a triple scoop of bondo.
Nickas is offline   Reply With Quote
10-23-2009, 04:57 PM   #2 (permalink)
fordman460
Posts: n/a
Re: 289 stumbling at part throttle.
I would check for fuel pump pressure and volume first.
10-23-2009, 05:06 PM   #3 (permalink)
Ausgal67
I agree sounds like low fuel supply.
Shouldnt be a mist should be a spray.
67 Galaxie 2 door Fastback
67 GTA390 Mustang
BF MK2 XR6 Ute
Ausgal67 is offline   Reply With Quote
10-23-2009, 05:30 PM   #4 (permalink)
r.n.r.racing
When was the last time that you changed your fuel filter? It sounds to me like you are not getting enough fuel to the carb. Filters are cheap and pretty easy to swap out and see if that makes a difference.
1964 Galaxie 500XL, 352cid, Cruise-o-matic, 9in rear, white w/white interior, all original american iron as it came from the factory
r.n.r.racing is offline   Reply With Quote
10-23-2009, 05:40 PM   #5 (permalink)
JCAllison
Hey Mr. N,
Sounds like what was happening with Ms. American. We all thought it was fuel related too. I had checked the Points and they were properly gapped. BUT, went ahead and put in New Points and a New Condenser.
You can't tell by looking at it whether a Condenser is functioning properly.
They're inexpensive and easy to install. Do that FIRST. It may solve YOUR problem. It DID the trick for Ms. American.
JC
10-23-2009, 06:59 PM   #6 (permalink)
coosbaylumber
Wasn't exactly what ailed a few years ago, but how are your valve springs? Holding things tight?
Wm.
Old Ford owner
10-24-2009, 07:34 AM   #7 (permalink)
Nourse
I had a 67 mustang in high school that did the same thing. How old is the Ignition coil? I would check fuel pressure and filter first and then move to the ignition next.
Nourse is offline   Reply With Quote
10-24-2009, 08:09 AM   #8 (permalink)
K2racer
Clean out the carb first, I bet it's debris in it.
I used to get it, but then the government changed what it was, and now I don't get it.
K2racer is offline   Reply With Quote
10-24-2009, 02:51 PM   #9 (permalink)
Nickas
Okay, so I popped the top on the carb and checked things out. Cleaned out what looked nasty. Changed the fuel filter at the carb and tested the condenser. Everything is solid in that regard. However I noticed a part number at autozone in their computer for another fuel filter. I checked it out and it appears to be for the fuel pump. Am I correct in this line of thinking? And also what would make the pump tick? Is this a sign of imminent failure?
10-24-2009, 03:17 PM   #10 (permalink)
Rich27028
how did you test the condenser???00
66 galaxie 352 -PS-PB-
Rich27028 is offline   Reply With Quote
Throttle Linkage Part bud168 Falcon Pages 2 10-01-2008 10:49 AM
C4 Part Throttle Shifting pbrown C4 Transmissions 5 03-02-2008 01:48 PM
Stumbling Carb Part 2 Mikes66 All Ford Techboard 28 05-26-2006 03:27 PM
Surging at part throttle keesor All Ford Techboard 5 08-27-2005 01:07 PM
Stumbling toward Woodward part 2 tim1859 The Garage 10 08-19-2004 04:18 PM
