Re: She's Alive!!
It sounds like you gassed the plugs. Did it turn over a lot before it started? If so, it was dumping gas into the cylinders and it saturated the plugs. Pull all the plugs and check them. I would replace them and make sure the ignition system is up to par. It is running, that is a start. Let the troubleshooting begin!
1962 Galaxie 500 2 door sedan(62A) http://www.cardomain.com/ride/3091676
The car is named Albert(Big Al, not Big Gal!) ¨Built not Bought¨
