10-28-2009, 08:08 AM   #1 (permalink)
mddyatv
C-6 Shift Kit which one are you using?
So I have a little extra cash this payday and looking to put in a shift kit in my 66, I was just wondering what brand you all are running and how easy it was to install. I am currently looking at the TCE 360000 Trans-Scat. from summit.
Thanks.
1966 Ford Galaxie 2 door fastback LTD
Factory Q code 428ci
power windows, seats, a/c
mddyatv is offline   Reply With Quote
10-28-2009, 10:19 AM   #2 (permalink)
drdano
Re: C-6 Shift Kit which one are you using?
I'm using the same kit and am very happy with it. I'm using the towing/firm calibration, not the full on competition shift style and its a nice clean crisp shift. The wifey hates the neck-snapper competition shifts, otherwise I would have used that instead. Installation is pretty easy, have to drop the pan and the shift manifold. Instructions are very good. I'd replace the pan with one that has a drain plug in it if you dont have one already. Now would be the time.
drdano is offline   Reply With Quote
10-28-2009, 02:37 PM   #3 (permalink)
monsterbaby
modified my own VB sep plate.
I second the buying a pan with a drain plug. You can get the cheaper chrome ones off evilbay for under $30 and they work fine (I have one on my 67) or go more expensive with a fancy alum pan but whatever you do I really do suggest swapping out the original pan.
monsterbaby is offline   Reply With Quote
b&m trick shift, hurst hot shift, type f, or dexron mercron? what do i use! greasemonkey85 C4 Transmissions 10 04-23-2008 01:11 AM
c4 column shift to floor shift 3154tm C4 Transmissions 3 10-07-2006 05:25 PM
Converting column shift to floor shift WinoTele Galaxie Pages 6 09-09-2005 10:49 PM
Colomn shift or floor shift???????? andysam All Ford Techboard 9 09-22-2004 04:11 PM
How 2 adjust manual trans shift rods on \'63 column shift? ventilo Galaxie Pages 3 07-29-2004 04:24 PM
