10-29-2009, 10:49 PM   #11 (permalink)
fordman460
Posts: n/a
Re: Idle ok, in gear not so much
After changing the vacuum advance canister, you may have to check and reset the points and re time the engine.
10-30-2009, 05:36 AM   #12 (permalink)
oneputtster
Good one, Deb! there were instructions in the box showing cars and # of CCW turns for each, but I couln'nt figure out how to turn the arm. I'll look in the tube.
Your idea gives a link to the symptoms. as the car gets warmer the vacuum might change, affecting the timimng per fordman, something like that?
Putts drives a 1965 Galaxie 500 4dr. 352 4V AC PS PDrumB cruis-o-matic.
oneputtster is offline   Reply With Quote
10-30-2009, 08:42 AM   #13 (permalink)
70XL
Does the carb have a choke? You want to set your idle with the engine fully warmed up. My guess is the problem lies in the stuff you changed in the distributor not being set up properly.
1970 XL, 351W originally 2V, now 4V
670 Street Avenger, Edlebrock Performer intake, Comp XE262H, Flowtech Headers
70XL is offline   Reply With Quote
11-07-2009, 04:33 PM   #14 (permalink)
oneputtster
After I put in the new Vacum advance things did not go so well,
So when the sun went down today I got out my neon timing light. I was off the mark by 6" or so (left side).
Jusr wanted all on this tread to know that it all turned out okay for me.
11-07-2009, 05:28 PM   #15 (permalink)
danv
So you've set the correct timing and everything is right now?
2003 Falcon BA XR8 Ute.
1972 Falcon XA GT.
1970 Galaxie 500 Sportsroof.
1963 1/2 Galaxie 500 Fastback.
danv is offline   Reply With Quote
11-08-2009, 11:09 AM   #16 (permalink)
oneputtster
Yes. Tip: get a new vacuum advance? get some new timing.
The idling at 1100 was cured mostly by backing off on the cold idle screw. Tip 2: What looks good on the bench doesn't always work out under operating conditions.
I took it on the highway this ayem and it ran past 70 without shaking (good). Oil not getting above 25 (bad), but water at a cool 182 (good). All that disassembly for painting killed the A/C (bad), But - winter coming on (good)! Heater barely putting out (bad). Three people admired my Gal this morning ... Good.. bad, good... I guess this is all our stories!
11-08-2009, 12:29 PM   #17 (permalink)
fordman460
Posts: n/a
Yup! That rod connecting the can to the points plate also locates it. Different can= different timing. Changing the point gap also alters the timing.
Should the emergency brake hold a Galaxie at idle in gear? Frank Galaxie Pages 6 02-16-2006 05:07 PM
Stang will not Idle in gear 66stang Mustang Pages (1965-1973) 15 01-19-2006 06:33 AM
302 idle problems - starts but won't idle siscrew Late Model EFI Techboard 5 05-18-2005 11:30 AM
Runs great in idle, wants to die in gear... Humphrey351 Truck Forum 1 11-04-2004 12:44 AM
What type of gear oil/lubricant to use in steering gear box and how to lube it?? mc All Ford Techboard 4 04-08-2003 04:48 AM
