10-28-2009, 05:27 PM   #1 (permalink)
stlzed
Help With 66 Galaxie Transmission ID!
I posted this in the C4 transmission forum but want to see if any Galaxie pros might be able to help me out also. I have a 66 Galaxie with a 289, all original, and am trying to determine what transmission it has. I crawled around underneath and the pan is pretty much perfectly square with 11 bolts. Has no bulges, turns, indentations in the pan from what I see, exactly square. On the left/driver side right above where shift linkage goes into the case I saw a C5 AP 7006 C. Or the last 2 digits could have been a B and a 0. But I'm pretty sure the first series is right, it was tough to see and in a bad spot, had to scrape away the crud. So again, looked like C5 AP 7006 C to me, or ending C could have been a zero. There was also a circle with a 29 in it and another circle with a 65 in it. I tried to measure the case length as best I can from where bellhousing/tranny case started to where it connected to the extension piece before tail, I measured about 10 7/8ths inches. The transmission appeared to be aluminum to me but I'm not sure, should have put a magnet to it. I know this probably won't help, but the tail had RF-C6DP-7A040-A stamped in it. Again, 289 motor, all original. Filler tube went into the side of the pan on passenger / right side. Can anyone help me out?
stlzed is offline   Reply With Quote
10-28-2009, 05:50 PM   #2 (permalink)
ShotRod64
Re: Help With 66 Galaxie Transmission ID!
Is the bellhousing and the rest of it all one piece or is the bellhousing seperate and bolted to the tranny.
Here's a place you can use the pan shape to ID it.
Ford Transmission IdentificationPan gaskets and filters for C
And here also
Ford rear wheel drive transmission parts: Bulkpart transmission parts
Always be yourself, because the people that matter don't mind, and the ones who mind, don't matter.
www.so-calgalaxies.com
www.galaxiesnw.com
10-28-2009, 05:51 PM   #3 (permalink)
65460
Google is your friend:
http://www3.telus.net/cbradley/TransIDChart.JPG
You have a C4
65460 is offline   Reply With Quote
10-28-2009, 05:58 PM   #4 (permalink)
It's a 65 C4
Honor!
10-28-2009, 05:59 PM   #5 (permalink)
dammitt Chuck, you beat me to it!
Honor!
10-28-2009, 06:13 PM   #6 (permalink)
stlzed
All - Bellhousing and transmission separate pieces, are bolted together. So early C4 then? Has a separate bellhousing, transmission, then a short spacer piece, then the tail piece, all bolted together. Thanks for all the help - much appreciated!!
10-28-2009, 06:28 PM   #7 (permalink)
stlzed
Transmission case is aluminum.
64 Galaxie transmission orangeggg All Ford Techboard 2 05-24-2009 08:52 AM
T5 transmission in a 62 Galaxie dazecars Galaxie Pages 0 06-07-2008 08:44 PM
67 Galaxie Transmission Swap jimb726 Galaxie Pages 4 08-25-2005 10:18 PM
Need a transmission for a 68 Galaxie Dixie1984 Galaxie Pages 7 10-31-2004 01:11 AM
T5 transmission behind a FE Galaxie toddfairlane Galaxie Pages 4 06-03-2003 08:26 PM
