10-29-2009, 07:06 AM   #1 (permalink)
aldaytona
Ugrades Front Sway Bar
Hi All,
Trying to fit a recently purchased upgraded front sway bar on my 66 500. The bar came from P-S-T and is just not fitting right. Anyone out there with any experience with this install?
Cheers,
Aldaytona
aldaytona is offline   Reply With Quote
10-29-2009, 08:27 AM   #2 (permalink)
432bullet
Posts: n/a
Smile Re: Ugrades Front Sway Bar
Originally Posted by aldaytona View Post
Hi All,
Cheers,
Aldaytona
I used a Quickor garage, [ nice part] on mine, i installed it with the eng out and front clip off. I think there some old posts that said they had to drop the lower a arm on one side to get the swabar in ?? Hope this helps
10-29-2009, 10:44 AM   #3 (permalink)
aldaytona
Every piece of info helps. Many thanks
10-29-2009, 02:08 PM   #4 (permalink)
Ggrahn
If you get the front end up, wheel off, you should be able to snake the bar in. I was able to reinstall my factory front bar with almost everything installed. Just takes a little wiggling.
Gary
66 Custom 500 390 2v
Ggrahn is offline   Reply With Quote
10-29-2009, 03:06 PM   #5 (permalink)
aldaytona
Got it installed, boy that 1-1/8" bar is sure a little heavier than the stock one! Many thanks for your suggestions. Next project the exhaust system...
10-29-2009, 09:38 PM   #6 (permalink)
oneputtster
I know it says don't tighten the end links too much but in my experience you need to tighten them up pretty good to keep them on.
Putts drives a 1965 Galaxie 500 4dr. 352 4V AC PS PDrumB cruis-o-matic.
oneputtster is offline   Reply With Quote
Front sway bar DAVIDE Mustang Pages (1965-1973) 10 04-08-2008 03:58 PM
Front Sway Bar, Should I take it out? Roarnracin All Ford Techboard 9 04-04-2007 01:12 PM
front sway bar dbu8554 Galaxie Pages 10 06-21-2005 04:18 PM
Front Sway Bar for a 79 F100 beegshot Truck Forum 6 04-01-2004 08:46 AM
Front sway bar diameter streetstang67 All Ford Techboard 3 11-27-2003 12:02 PM
