10-31-2009, 02:22 PM   #1 (permalink)
ford dude
1964 galaxie lights wiring
1964 ford galaxie ....if i turn my park lights on my signal lights dont work,,turn off park lights the signal lights blink or at least the right side does ,,when i turn on the left the both rear lights blink... anyone ever had that problem,,ive been moving wires around all day and cant find a combination or solution...
ford dude is online now   Reply With Quote
10-31-2009, 03:00 PM   #2 (permalink)
gentz
Re: 1964 galaxie lights wiring
seems like a bad ground, also make sure your double filament bulbs arnt shorting across both pins
If it aint Broke lets modify it!
1962 Ford Galaxie 500, cruise o matic, 292.
gentz is offline   Reply With Quote
10-31-2009, 04:26 PM   #3 (permalink)
galax-z
bad ground for sure
galax-z is offline   Reply With Quote
10-31-2009, 05:04 PM   #4 (permalink)
r.n.r.racing
I had a similar thing happen except it was with my front right that was messed up. The problem ended up being the front right signal housing wasn't grounded good enough to the bumper from corosion between the two. I would bet that if you were to pull your housing out of the bumper and clean it off real good and also clean the bumper area around the signal to get a good metal to metal contact then your problem would probably go away. Also check the bulbs inside the sockets and make sure that there isn't any corrosion inside there.
1964 Galaxie 500XL, 352cid, Cruise-o-matic, 9in rear, white w/white interior, all original american iron as it came from the factory
r.n.r.racing is offline   Reply With Quote
11-01-2009, 09:29 AM   #5 (permalink)
ShotRod64
Not sure if this will fix the problem either but I had problems with turn signals and brake lights and it was in the plug that goes into the firewall to the fuse box was corroded. Wouldn't hurt to check it and clean it up if needed.
11-02-2009, 07:03 AM   #6 (permalink)
jerrym3
A little bit off topic, but has anyone else had the problem of the bulbs popping out behind the dash cluster? Seems like the factory wiring is too short.
Wasn't a problem when I was 26, but at 66, getting under the dash to insert them back into the holes is getting really old.
jerrym3 is offline   Reply With Quote
11-02-2009, 07:34 AM   #7 (permalink)
gbic1
More than likely a bad ground but check to see if a recient bulb replacement had the wrong bulb installed. That will cause all type of problems. ( I.E. single filament in place of dual)
1964 Galaxie 428
1966 Mustang 302
1967 Cougar 390
1968 F250 Camper Special 390
11-02-2009, 02:51 PM   #8 (permalink)
ShotRod64
Good idea gbic, i've done that myself not paying attention. Doesn't work very well!
Jerry, nope, only when I take the cluster loose to hook up the speedo cable. Maybe there is something causing weight on the wires to pull them loose. There are little metal things on each side of the socket that keep them in place. Maybe they need bent out just a little so they hold tighter.
11-02-2009, 04:27 PM   #9 (permalink)
galax-z
i"ve had the same problem. i think the wires get shorter with age
11-03-2009, 05:28 AM   #10 (permalink)
oneputtster
LOL, so do we all!
Putts drives a 1965 Galaxie 500 4dr. 352 4V AC PS PDrumB cruis-o-matic.
oneputtster is offline   Reply With Quote
wiring for back ups lights and safety switc h rasmith1 Galaxie Pages 16 07-27-2009 05:11 AM
wiring up some lights hepcat69 The Garage 1 04-18-2009 01:45 PM
Wiring Tail Lights 1965Comet Falcon Pages 2 01-03-2009 06:21 AM
wiring in idiot lights putts1 Galaxie Pages 22 01-13-2007 08:54 AM
wiring diagram for 1964 galaxie mreifers All Ford Techboard 0 05-20-2002 07:45 PM
