10-31-2009, 03:27 PM   #1 (permalink)
Nourse
Front Coil Spring on a 1965
The 521 is to heavy for the springs that are in it. I think they are the orginal springs for the car. I was looking at the moog 8336 springs they are a little more heavier and sit at 12 inch ride height then the factory 11inch height. Has anyone ran into this problem yet and if so what springs are you running? I really don't want to put in the wrong springs and have to do it again!
Nourse is offline   Reply With Quote
10-31-2009, 04:01 PM   #2 (permalink)
shiftthis
Re: Front Coil Spring on a 1965
i put 69 mercury colony park station wagon springs for the 429 with air cond. in my 66 country sedan wagon that had an all iron 460 in it without air and they were perfect
shiftthis is offline   Reply With Quote
10-31-2009, 05:42 PM   #3 (permalink)
65460
I originally had a 352 in my car and now have 466/C6 with aluminum heads and intake.
All I did was install a new set of big block springs and have had no issues in more then 25,000 miles of cross country and drag strip driving
In my opinion, the car with new springs sits high enough. I personally would not want the extra 1 '' that the springs your talking about would add to the ride height
65460 is offline   Reply With Quote
10-31-2009, 09:52 PM   #4 (permalink)
shiftthis
with new front spring and new rear springs my car sat level you can see a photo at...Pictures by supershifter2 - Photobucket my car was also setup for handling with 275-60-15 tires front and rear mounted on bassett 15x8 front and 15x10 rear ginuwine stock car wheels with 5x5 bolt pattern strange axles rear 66 Lincoln continental rotors up front redrilled for 5/8 studs proshock shocks Sweet Mfg 14:1 steering box and other stuff. car rode nice and handled really well on the curvey los angeles mountain roads.
10-31-2009, 09:59 PM   #5 (permalink)
shiftthis
what makes you think these raise the car 1" ? did you try these springs ? just wondering !!!!!!!
10-31-2009, 10:09 PM   #6 (permalink)
Domino
I have installed new Moog springs in about 20 different cars ranging from the early 60s to the 90s. The Moog springs seem to always make the cars sit a little higher than stock springs. Since your car shares the same basic front suspension from 65 to at least the early 70s, I would find a car with a similar engine like Shftthis suggested.
1962 Galaxie 500 2 door sedan(62A) http://www.cardomain.com/ride/3091676
The car is named Albert(Big Al, not Big Gal!) ¨Built not Bought¨
Domino is offline   Reply With Quote
11-01-2009, 08:58 AM   #7 (permalink)
65460
Because the OP stated this:
" I was looking at the moog 8336 springs they are a little more heavier and sit at 12 inch ride height then the factory 11inch height. "
I understood that to mean that the Moog springs would make the car sit 1 inch higher (12 inches) then (new) factory springs, 11 inches high
11-01-2009, 01:05 PM   #8 (permalink)
v8shadow
my post didnt apply.
KEN
Factory 65 Galaxie 500 390/4v
v8shadow is offline   Reply With Quote
11-02-2009, 09:34 AM   #9 (permalink)
Nourse
65460 what headers are you running? I'm running maddog header that go under the k member I have about an 1.5 of clearance from the ground, that's why I was thinking of raising it up a little.
11-02-2009, 01:35 PM   #10 (permalink)
shiftthis
i used the 69 mercury colony park station wagon springs with a 429 & a/c and use the Crites headers that have the 4 front pipes going uder the k-member and they hit the ground even after i put custom valved stock car shocks on so i completely reworked the headers and routed the 4 front pipes back over the k-member like Hooker headers does with the 390-428 headers for the 65-68 Galaxie. the crites headers are a very poor cheap design and i will never buy them again.
front coil spring insulators donwhis Galaxie Pages 14 03-16-2009 05:29 PM
Front coil spring rates? mc Mustang Pages (1965-1973) 5 08-14-2008 10:53 PM
Mustang Front Coil Spring Rates mc All Ford Techboard 0 07-23-2008 10:44 AM
Coil spring/leaf spring advice 63Sean Galaxie Pages 4 02-09-2005 04:58 AM
Front Coil Spring question? growlin351w All Ford Techboard 2 07-13-2003 01:09 PM
