11-01-2009, 08:46 AM   #11 (permalink)
Rich27028
Re: FE Engine Identification
and -- the intake should have 4 numbers and 1 letter on it --
66 galaxie 352 -PS-PB-
Rich27028 is offline   Reply With Quote
11-01-2009, 08:51 AM   #12 (permalink)
unioncreek
The OP said that it has a 4100 on it. Check the way the spark plugs are angled, an FE are \ \ / / .
Bobg
Bob G
1962 Galaxie 500 XL with a 390 Thunderbird Special.
unioncreek is offline   Reply With Quote
11-01-2009, 09:01 AM   #13 (permalink)
dacofa
First is it even an FE or 289 engine? Quick way, valve covers overlapping the intake manifold or the water pump is not bolted to the timing cover. Evither of those 2 and it's an FE. If the other way, it's a 289.
Lead, Follow, or get the F%$K out of my way.
11-01-2009, 10:38 AM   #14 (permalink)
He asked
I would really like to have a good guess as to what I have and am putting in my Galaxie. It has an autolite 4100 (the 600CFM version), and I took a pic of the following number on the intake with my phone. It has the casting # C6AE and then below it 42 - G. Does that give us any clues?
The INTAKE in your picture is a FE intake. It's a 390 428 casting that can and was used on damn near all FE engines.
You can't tell what you got in an FE block unless it's cross bolted, or a 501 mirror block, all others are guessing games as to the cubes as that engine block had every combo of cubes from 332 to 428...Measure your stroke to find out what crank you got like the guy's above said. The engine is equipped with all the tools necessary {except the plug wrench} to do this.
Honor!
11-01-2009, 04:43 PM   #15 (permalink)
Jamersan
I apologize for the confusion. I bought the LTD thinking the FE engine in it was the original one, and that the VIN would tell me what it was (or at least a good guess as to what it was). However, the VIN coded out to the small block, which this engine is obviously not!
It is definitely an FE, and it has an Autolite 4100 carb on it (4 barrel, 600 CFM I believe - 1.12 casting on side or something like that).
I didn't make it to the car today. I attended a car show near it, but time did not permit me to swing by the car. I'll take a look in the next couple of weeks and get the stroke.
Jamersan is offline   Reply With Quote
Engine Identification ?? 64ranchero All Ford Techboard 2 02-13-2006 05:38 PM
Engine Identification Destro Falcon Pages 1 03-15-2005 12:17 AM
Engine Identification Project69 All Ford Techboard 1 12-24-2004 12:11 AM
engine identification carsmetalsusa All Ford Techboard 3 06-18-2003 08:58 PM
302 Engine Identification BDRachel All Ford Techboard 2 05-02-2002 01:14 PM
