10-31-2009, 06:33 PM
Jamersan
FE Engine Identification
I am pretty certain that it is impossible to tell by looks/numbers on an FE engine as to which variety it is. However, is there a way to make an educated guess? I purchased a 66 LTD 4 door that had been wrecked because the engine was just redone.
I checked the VIN today, and the car was a C code ( 289-2V Challenger V-8, 200 hp @ 4400 rpm, 282 ft-lbs @ 2400 rpm, 9.3:1 compression ratio).
I would really like to have a good guess as to what I have and am putting in my Galaxie. It has an autolite 4100 (the 600CFM version), and I took a pic of the following number on the intake with my phone. It has the casting # C6AE and then below it 42 - G. Does that give us any clues?
I'll see the car again tomorrow morning (it is about 50 miles away) if I need to get any more numbers/info.
10-31-2009, 06:40 PM
danv
Re: FE Engine Identification
Anyone can swap an intake over.
What you need is the block and head casting numbers to get an accurate as possible ID.
2003 Falcon BA XR8 Ute.
1972 Falcon XA GT.
1970 Galaxie 500 Sportsroof.
1963 1/2 Galaxie 500 Fastback.
10-31-2009, 06:43 PM
Jamersan
I can get the head #'s, but where is the block casting # on these old FE's?
10-31-2009, 07:28 PM
My427stang
Block casting wont do much, heads gets you some info.
Unfortunately, most all from that era are C6ME-A block, regardless of displacement. Heads may tell you a little more, but even then they used them across all kinds of short blocks
Best thing to do is to take a wooden down with you, pull a plug and turn it over. Mark the dowel at the top of the stroke and the bottom.
The difference will be:
3.5 inches = 352/360
3.78 inches = odds are 390 unless crossbolted, but slight odds could be 406
3.98 = 410 or 428
It equates to 3.5 / 3.75 / 4 inches all far enough to even WAG with a ruler and a dowel.
My guess is 352 or 390
70 Sportsroof, 427 FE/489 cid, TKO-600, 3.70, A/C. Currently undergoing full MAF port EFI conversion with CnC ported Victor/1200 cfm throttle body. Stay tuned!!!
11-01-2009, 01:24 AM
wreckingball
"Read it again......the car WAS a C code 289. At least that's how I read it."
Read it again and deleted my post
1962 Ford Galaxie 500 Club Victoria Q Code 3x2v 4spd
1967 Ford Galaxie 500 428 3x2v 4spd
1969 Ford Mustang Mach 1 351w 4 spd
Reason: Incorrect info.
11-01-2009, 01:47 AM
Bobby, whut in the hail??????
I checked the VIN today, and the car was a C code (289-2V Challenger V-8, 200 hp @ 4400 rpm, 282 ft-lbs @ 2400 rpm, 9.3:1 compression ratio).
Why are you asking about an FE engine???? A 289 is a small block ford....
Honor!
11-01-2009, 03:13 AM
danv
1972 Falcon XA GT.
11-01-2009, 03:37 AM
JCAllison
Originally Posted by My427stang
Best thing to do is to take a wooden dowel with you, pull a plug and turn it over. Mark the dowel at the top of the stroke and the bottom.
Hey Mr. M427S,
If one forgets to take a dowel, one can use the Dip Stick.
JC
11-01-2009, 06:12 AM
#9 (permalink)
My427stang
Originally Posted by JCAllison
Hey Mr. M427S,
JC
Indeed!
11-01-2009, 08:28 AM
#10 (permalink)
coosbaylumber
This engine have a two barrel carb or a four barrel one? I get blurred images here only.
Identifying the carbonator will eliminate 1/2 about the engine possibilites, as 428 engines did not come with two barrel carb's normally.
Wm.
Old Ford owner
