11-01-2009, 10:21 AM   #1 (permalink)
rod123
Talking push rod tool
I will soon doing the engine work on my 63.5.
[SIZE=2]To start building the engine and I have a set of C6AE-R heads that I will be using on my 390 engine. The heads have been ported polished with CJ valves and hardened seats. I will be using a high energy cam
[SIZE=2]I have already purchased a comp cam extream energy CL33-248-4 with double springs and lifters. [/SIZE]
[SIZE=2]The cam specks are [/SIZE]
[SIZE=2]RPM RANGE 1800 TO 6000[/SIZE]
[SIZE=2]VALVE TIMING 0.006[/SIZE]
[SIZE=2]LOBE CENTER ANGLE 110[/SIZE]
[SIZE=2]INTAKE CENTERLINE 106[/SIZE]
[SIZE=2]VALVE LASH HYD[/SIZE]
[SIZE=2]DURATION 274 INTAKE EXHAUST 286[/SIZE]
[SIZE=2]DURATION @ .050 LIFT 230 INTAKE EXHAUST 236[/SIZE]
[SIZE=2]VALVE LIFT 0.562 INTAKE EXHAUST 0.565[/SIZE]
[SIZE=2]LOBE LIFT 0.327 INTAKE EXHAUST 0.327[/SIZE]
[SIZE=2]VALVE TIMING @0.006 LIFT[/SIZE]
[SIZE=2]INTAKE OPEN BTDC 31 CLOSE ABCD 63[/SIZE]
[SIZE=2]EXHAUST OPEN BBDC 77 CLOSE ATDC 29[/SIZE]
[SIZE=2]The car will have two afb four barrel carbs the cfm I think is around 600 each.[/SIZE]
[SIZE=2]4 sp tranny I do not know the tranny ratio but I will see if I can find out.[/SIZE]
[SIZE=2]Long tube ceramic coated headders.[/SIZE]
[SIZE=2]3.50 gears posi out back.[/SIZE]
[SIZE=2]MSD electronic ignition.[/SIZE]
[SIZE=2]Deep sump pan with melling pump.[/SIZE]
This is a long winded way to ask what size push rod do I need or can someone sell me a single push rod to make one adjustable homemade to get in the ball park about length.
It looks like there are several possibilites.
[/SIZE]
Rod and Alica
63.5 Galaxie 3 pedals
69 Torino Convertible
rod123 is offline   Reply With Quote
11-01-2009, 11:20 AM   #2 (permalink)
fordman460
Posts: n/a
Re: push rod tool
That's a common store bought part. Here is one example. JEGS 80683 JEGS Adjustable Pushrod Length Checker This one is for the stock FE hydraulic size.
11-01-2009, 12:13 PM   #3 (permalink)
rod123
Re: push rod tool
Thanks for the link...
The price was not bad so I ordered one.
Rod and Alica
Win A Nice Air Tool For Your Tool Collection Calspec The Garage 81 01-09-2009 05:12 PM
Tool time - Flare Pro 4 in 1 Flaring and Swaging Tool Beoweolf The Garage 8 08-02-2006 12:13 AM
push rod drops ron All Ford Techboard 0 04-04-2004 07:21 PM
push rod removal...??? cometkid All Ford Techboard 3 01-22-2004 05:00 PM
push rod removal...???? cometkid Falcon Pages 3 01-22-2004 01:39 PM
Probe Industries
