11-01-2009, 11:34 AM   #1 (permalink)
mddyatv
PCV Valve question
I have always eleminated the pcv valve on my older cars we do not have emissions and I was at the part store yesterday the guy told me that if I remove the PCV valve i would lose horse power, Is this correct? I thought it was just for emissions. any help on this would be much appreciated.
1966 Ford Galaxie 2 door fastback LTD
Factory Q code 428ci
power windows, seats, a/c
mddyatv is offline   Reply With Quote
11-01-2009, 12:55 PM   #2 (permalink)
winged one
Re: PCV Valve question
Positive Crankcase Ventilation.
One of the things you do by eliminating the PCV is allow the buildup of pressure in the engine, that can cause the oil to be pushed up through the dipstick.
winged one is offline   Reply With Quote
11-01-2009, 01:10 PM   #3 (permalink)
mddyatv
but if you put a breather on, it should not build up pressure right? I have never had oil come thru the dipstick on the Galaxie. or on my bronco when I changed it.
11-01-2009, 03:40 PM   #4 (permalink)
galax-z
pcv valve is the best thing to happen to the internal combustion engine. blowby from the rings collects in the crankcase. this results in water and sulfuric acid buildup in the oil. pcv doesn't affect horsepower or gas milage. this is a win win situation. you should not remove it
galax-z is offline   Reply With Quote
11-01-2009, 03:52 PM   #5 (permalink)
PCV is not necessary, but it increases the life of the oil drastically {see the above mentioned reasons of contamination}
But it will NOT effect the HP of your car.
Honor!
11-02-2009, 12:34 PM   #6 (permalink)
winged one
Your original post did not mention a mitigating release of gases (adding a breather). Thus I answered whether someone should just eliminate the PCV valve.
c-4 valve body question C4explosive C4 Transmissions 3 02-22-2008 11:00 AM
Valve clearance question ironmachineus All Ford Techboard 2 05-23-2007 03:04 PM
valve cover question dyna109 All Ford Techboard 2 12-12-2006 04:46 PM
PCV VALVE QUESTION? fastranger All Ford Techboard 3 08-15-2005 10:15 AM
Valve Cover Question psivory All Ford Techboard 7 04-28-2005 11:33 AM
