Originally Posted by ShotRod64
I think most here make their own actually since most aren't available.
Deb
Back when, on my 1963 1/2 I made my own out of 1/8 pressed wood from lumber yard, and then got materials from local upholsterer. Weighted down the old one with cylinder heads as used old one for a pattern, and glued new material on top using contact cement.
Cost? Less than $20.
Old one was up against a leaky rear window, had warped, previous owner had carved in some BIGGIE speaker holes via the trunk. Speakers were long gone, but not the holes.
You need to be critical with upholstery shop material, and not select just whatever they hand you too. Needs to match your idea too.
Wm.
