11-01-2009, 08:44 PM   #1 (permalink)
one37tudor
FE block ID
Does anyone have one of the Ford engine books that identify the applications for specific blocks?
I have a C7ME-A block and I can't find my books right now? On line what I can find is that this is a 67-70 428 or 68 428 Shelby GT500?
I don't trust that as by my crude bore measurements (with a ruler) it appears to be a 4" bore? I can't measure the stroke right now as the motor has set on the ground for a long time and is froze up.
I suspect this is a 67 mercury 352 block but can't find anything on line that would substantiate that thought.
Scott...
11-01-2009, 09:57 PM   #2 (permalink)
fordman460
Posts: n/a
Re: FE block ID
Crank #'s and bore size are only true indicators of the engine. 4.05 is a std bore for several engines. No 352's in '67.
11-01-2009, 10:14 PM   #3 (permalink)
Ausgal67
Re: FE block ID
According to my book, should be a 428 for 67-68, and should have a 4.13" bore.
67 Galaxie 2 door Fastback
67 GTA390 Mustang
BF MK2 XR6 Ute
Ausgal67 is offline   Reply With Quote
11-02-2009, 07:55 AM   #4 (permalink)
Re: FE block ID
No chance Ausgal, even for someone with bad eyes, .13 of an inch is EASILY readable with a ruler or a tape measure.
Meaning that 4.0 is readily differentiated from 4.13.
I'm 99.9% sure it's a 67 352 block. Who in the world let's a 428 block sit on the ground out in the open...?
Honor!
11-02-2009, 08:25 AM   #5 (permalink)
coosbaylumber
Re: FE block ID
I do...
It was initially covered in plastic for was going to move, and that was going to take only 1-2 weeks, but wound up taking four months. Then going back and loading up the near complete engine. The plastic sheet had eroded and blew away by then. A 427 will also stay outside quite easily too.
Wm.
Old Ford owner
11-02-2009, 08:34 AM   #6 (permalink)
Re: FE block ID
OMG Will! How could you!!!
Honor!
11-02-2009, 12:02 PM   #7 (permalink)
Ausgal67
Re: FE block ID
I think you will find it is C7AE that is the 352 block for 67.
I'm no expert as i am new to FE's but i have been doing a lot a reading, and the FE is one family of engines that sure has some parts changes through it's life.
David.
67 GTA390 Mustang
BF MK2 XR6 Ute
11-02-2009, 12:44 PM   #8 (permalink)
Re: FE block ID
I wasn't speaking about parts interchanging, I was referring to the ease of telling 4.0 from 4.13 on a ruler or even a tape measure...
Wasn't trying to cast doubt on you.
Honor!
11-02-2009, 01:13 PM   #9 (permalink)
64Ragtop
Re: FE block ID
Ford FE Engine Block Casting Numbers - FORDification.com
64Ragtop is offline   Reply With Quote
11-02-2009, 01:16 PM   #10 (permalink)
fordman460
Posts: n/a
Re: FE block ID
Check the bore with something more accurate. 4.00 is 332/352, 4.05 is 360/390/410, 4.13 is 406/428. Crank determines the rest. Casting #'s won't tell you much and I haven't found any book that matches what myself and others have found to be true.
Big block radiator with small block 1968 9t3lightning Galaxie Pages 1 10-28-2007 03:32 PM
New 8.20 sbf boss racing block vs worlds block stoker All Ford Techboard 35 12-06-2006 10:23 PM
E7TE small block heads on C8OE block Kman All Ford Techboard 6 06-08-2006 10:40 AM
351W lightning block vs standard roller block mustangzrule All Ford Techboard 6 08-27-2004 09:53 PM
Anyone use a big block fuel pump in a small block? mc All Ford Techboard 4 04-21-2003 03:34 AM
