11-06-2009, 12:28 PM   #1 (permalink)
jimmife
oil pressure relief valve
Hi Folks
Does anyone know if the 1962 406 had the oil pressure relief valve at the rear of the block?I am going to check my guage and see if it works properly.I am getting 100 psi on start up and goes down to about 80 when warmed up.Any tips would be appreciated.
I will try again
jimmife is offline   Reply With Quote
11-07-2009, 04:57 AM   #2 (permalink)
5851a
Re: oil pressure relief valve
As far as I remember my 62 replacement block (non crossbolt) has it.
11-07-2009, 08:07 AM   #3 (permalink)
coosbaylumber
I think that some of the 406 motors did and some did not. 1962 was the division year and depends upon how old your block is to begin with, is a marker as to if they did or did not then. Is mentioned in my old booklet by Ray Brock obtained from Ford many years ago. Sort of like the 406 cross-bolt controversy.
Wm.
Old Ford owner
11-10-2009, 11:03 AM   #4 (permalink)
jimmife
Thanks guys.My 406 is a later block, because it came in my XL build date aug.10th.1962
I will try again
11-10-2009, 08:09 PM   #5 (permalink)
coosbaylumber
You should easily by then have a rear exit pressure relief valve. Only the end of 1961 and the first couple months of 1962 had the normal version.
You got a more normal one then. Operation is mentioned via the Brock booklet for 1962 engines.
Wm.
Old Ford owner
C-4 Tranny pressure relief valve? Lpolonkey C4 Transmissions 2 04-07-2009 08:54 PM
Increasing oil pump pressure by shimming the prssure relief valve ville All Ford Techboard 13 01-05-2009 09:10 PM
Pressure relief spring and valve black93lx C4 Transmissions 5 12-30-2006 08:43 PM
valve relief size on speed-pro pistons steharz All Ford Techboard 0 03-13-2004 05:06 PM
Piston Valve relief for 514 Eagle stroker kit Countrywi All Ford Techboard 0 02-05-2004 04:40 PM
