03-25-2003, 08:06 PM   #1 (permalink)
JoeGT
Porting Tools
Hi all,
Been posting on Torino Cobra forum and have just suscribed to Ford Muscle, I have learned so much I've had to start printing my e-mails and forums and cataloging them for future reference! Thanks to everyone..
New question.. What kind of tools is everyone been using to port? I'm getting ready to buy a die grinder to port my 351c heads and want to get a good one! I hate buying something and it not be good enough to do what I want it to.
Thanks,
JoeGT
1970 Torino GT
351c
JoeGT is offline   Reply With Quote
04-02-2003, 03:37 PM   #2 (permalink)
Revolutionary
Porting Tools
Hey there, I port heads on pretty much a daily basis between valve jobs, boring and honing blocks etc. and my preference for a grinder is the Milwaukee 5192 for about $250 or so if you are on a budget and don't want to spend a ton of $$$. There is the more powerful Milwaukee grinder but it is about $100 more and weighs a bit more - believe me your arms will ache after a while. I get all my other supplies from Cylinder Head Abraisives out of Sacramento, CA 800-456-5474. A double cut oval shape burr like #SE5 does a great job of removing tons of metal fast. A single cut SE4 is good for smaller radii like around valve guides and the single cut leaves fewer 'scars'. I use the Pink stones PS186X for cleaning up the port of grinder marks then finish with a 60 grit cartridge roll on the intake and an 80 grit on exhaust. Not giving away my secrets for making aluminum heads look so good though...
Those would be what I consider the minimum essentioals for a starting porter. Of course my first set of heads was done with a Dremel, ugh. Not recommended as it takes about five times longer.
Tip on the grinder - cast iron doesn't cut well with the grinder moving 18,000rpm so I built a variable speed switch using a HD dimmer switch from Home Depot wired to it's own outlet and I can change speeds depending on what metal and burr I am using.
Revolutionary is offline   Reply With Quote
08-20-2003, 07:18 PM   #3 (permalink)
Luckylyn
Porting Tools
Hi,
Heres another idea for you, I have used this model of Dumore forever. I use carbide
burrs and pink stones with sandpaper rolls
to finish,[img]/phpBB/images/smiles/icon_wink.gif[/img]
http://www.jlindustrial.com/catalog/...?id=DUM-10321L
Luckylyn is offline   Reply With Quote
09-03-2003, 04:47 PM   #4 (permalink)
JoeGT
Porting Tools
Does anyone use the sanding grease with there cartridge rolls??
04-06-2005, 10:31 PM   #5 (permalink)
EricG
Porting Tools
Here's a link on some interesting porting stuff:
http://www.theoldone.com/articles/b16a_head/
This site has some crazy stuff on it. Lot's of heavy information in those articles. It would be interesting to experiment with some of those theories.
<font size=-1>[ This Message was edited by: EricG on 4/7/05 9:33am ]</font>
EricG is offline   Reply With Quote
04-07-2005, 11:09 AM   #6 (permalink)
n2omike
Porting Tools
Read the posts below concerning 'Porting Safety' and 'Die Grinders'.
There is a lot of good info below to read through.
Good Luck!
07-31-2005, 06:39 PM   #7 (permalink)
ironmachineus
Porting Tools
The Eastwood company has a complete porting kit. Try:
http://www.eastwood.com/shopping/pro...rd=porting+kit
ironmachineus is offline   Reply With Quote
