04-09-2004, 01:09 PM   #1 (permalink)
Revolutionary
ported smogger heads
I am swapping heads out and decided to flow my old D8OE heads that I did a little porting on last year. Still using the stock 1.78/1.45 valves in there I will compare them to a later model E7TE since I don't have flow numbers on my heads as stock.
stock E7te
in .100 .200 .300 .400 .500
52 95 132 141 154
ex 39 74 98 104 107
ported D8oe
in 49 97 139 166 179
ex 41 72 105 127 138
Not terribly impressive but not too bad for basically just bowl work in the intake and knocking out the smog bumps on the exhaust. At least it was good enough to run 8.65 in the 1/8 in my 86 mustang with 8.25:1 compression. That equates to about 13.6 in the quarter.
I have a set of D2OE heads cut for 1.94/1.5 valves that I will be putting on the flowbench soon.
Revolutionary is offline   Reply With Quote
05-06-2004, 10:28 AM   #2 (permalink)
inetj
Can 1.94/1.5 valves be cut into D8 heads and newer?
Thanks.
inetj is offline   Reply With Quote
07-14-2004, 08:28 AM   #3 (permalink)
tonys10sec306
i have a set of dooe 351w . they have bowl work abd bigger valves. the heads flow 197/179
tonys10sec306 is online now   Reply With Quote
