08-10-2004, 01:04 AM   #1 (permalink)
Stangboy69
Port Matching Heads and Intake
I have TFS Twisted Wedge heads and an Edelbrock Performer intake. I want to port match the intake to the heads using a felpro gasket similar to the article in the tech section... any tips on doing this? Things to avoid?
Stangboy69 is offline   Reply With Quote
08-10-2004, 05:43 PM   #2 (permalink)
tonys10sec306
TAKE YOUR TIME!!!.Other then thats its pretty easy
08-11-2004, 03:00 AM   #3 (permalink)
Stangboy69
Hey thanks man. Suggested tool for porting?
Im completely new to any kind of porting whatsoever so any other tips would be much appreciated...
08-12-2004, 02:18 PM   #4 (permalink)
FHIprez
You can order everything you need from Eastwood online and many other places to be sure. It's best to have a die grinder either pneumatic or electric (the pneumatic is much cheaper, but you have to have a pretty big compressor to keep up with the tool). If you purchase a die grinder get one with a rear discharge for the air. It will be much appreciated by your eyes (you wont get as much crap blown in your face). Wear a good dust mask in the very least, a good respirator at best. TAKE YOUR TIME! Eastwood has an assortment of bits that will make the job easy. DONT polish your intake area. It needs to maintain a semi ruff surface to help mix the fuel and air properly. If you polish it the air will outrun the fuel and the fuel won't atomize with the air properly.
Use baby steps in removing the material and do a little bit in each port, rather than completing one port then moving on to the next one. This will help keep your work uniform, not making one port bigger than another. Oh, and let the tool do the work, this is part of the taking your time bit, meaning don't push too hard to make it go faster. You will wad bits too quickly if you are using too much pressure. A good bit should cost around $30 and one should do the job no problem if you go slow.
Well there are a bunch of other things to be sure, but these are some highlights that come to mind.
Nick
FHIprez is offline   Reply With Quote
08-30-2004, 07:07 AM   #5 (permalink)
MAT88GT
http://www.mustangcentral.net/tech/intake_index.htm
http://diyporting.com
http://www.mustangcentral.net/tech/port.html
http://www.mustangcentral.net/tech/e7.html
'89 Mustang Coupe
Your typical pos Mustang
1996 F150, extended cab, long bed, 18's, duals and a big ol' grandpa topper
<font size=-1>[ This Message was edited by: MAT88GT on 8/30/04 7:10pm ]</font>
MAT88GT is offline   Reply With Quote
