08-19-2004, 07:50 PM   #1 (permalink)
maxSleeper
pics! nearly done! ported e7 heads
here's some pics of my heads they are almost completely finished mabye about 6 hours left to complete them mostly cleanup and some minor changes mainly on the exhaust port i will remove the guides flish with the roof and i will remove more pinch at the pushrod holes if anyone has any helpful advice feel free this is my first time porting
maxSleeper is offline   Reply With Quote
08-20-2004, 11:47 AM   #2 (permalink)
TALON
Good Morning
goto diyporting.com. this site has some great info on porting the e7 head
Jim
TALON is offline   Reply With Quote
08-30-2004, 07:04 AM   #3 (permalink)
MAT88GT
whats the thinking behind the exhaust port exit? I've personally never seen anything like that
MAT88GT is offline   Reply With Quote
08-30-2004, 08:03 AM   #4 (permalink)
tonys10sec306
Looks good so far
08-31-2004, 02:12 PM   #5 (permalink)
maxSleeper
The idea with the exhaust port is to smooth it out and open the window without messing with the radius and not to overhshape the roof
the exh port on the e7 flows best in the top half corners and walls by making this area larger/smoothing it increases flow mainly at higher lift overdoing this can hurt low lift velocity in the same area
i dont port match exhaust if you see the circles scribed on the exhaust thats my port size in the header the header I.D. is matched to the gasket other than the bolt area
when i port match the intake i only open it up to the smallest pinch i have in the intake runner (pushrod bumps) not the entry size
.Jake
<font size=-1>[ This Message was edited by: maxSleeper on 9/1/04 2:18am ]</font>
