11-16-2004, 09:54 PM   #1 (permalink)
heathbeck
ACID PORTING
Can anyone explain the process of acid porting, and the materials needed to do it.
thanks
heathbeck is offline   Reply With Quote
11-17-2004, 11:12 AM   #2 (permalink)
revhead
ACID PORTING
this process is very dangerous . all porting should be done totally sober. And dont forget your safety glasses.
revhead is offline   Reply With Quote
11-21-2004, 10:07 AM   #3 (permalink)
tonys10sec306
ACID PORTING
why do you want to port the heads that way??
11-21-2004, 12:36 PM   #4 (permalink)
mavman
ACID PORTING
Friend of ours has talked about it. They run roundy-round stuff and their class rules state "no porting"...... This is where acid porting comes into play. The ports look totally stock, but are in fact "hogged out" by the acid. That's how they measure the ports around here, just a visual to make sure the die grinder hasn't molested them.
11-22-2004, 11:37 AM   #5 (permalink)
Late91GT
ACID PORTING
remember this sometimes less is more! More velocity = more power than a runner that is to large.....match everything up and it should work well. I wished I could help with acid porting, have heard a bunch of it but never have seen it done! good luck
Ben
Late91GT is offline   Reply With Quote
11-22-2004, 07:41 PM   #6 (permalink)
ACID PORTING
Do a test... this might work!!!
Port a nice cast head, then get some rough grade blasting crystals, and after smoothing out the port work hit it with the blasting crystals. They will get a nice rough cast look to them if you do it just right...
02-06-2005, 12:20 AM   #7 (permalink)
Cyclone Joe
ACID PORTING
They submerge the ports with Nitric acid. The nitric acid solution concentration is known, as is the rate at which the acid will eat the material. Once the ports are eatin' enough, the acid is removed and the port is neutralized, and you're done!
Its pretty common in the aerospace industry.
Joe
Cyclone Joe is offline   Reply With Quote
