05-27-2006, 09:24 PM   #1 (permalink)
dsfordguy
How much to make 351c 4v heads accept adjustable rockers?
Just asking for a rough estimate of what its going to cost to get my cleveland 4v closed chambered heads machined to accept screw-in studs for adjustable roller rockers.
dsfordguy is offline   Reply With Quote
05-28-2006, 09:39 AM   #2 (permalink)
ou812
Should be around $60.00 a head to mill and tap the holes.
05-28-2006, 05:27 PM   #3 (permalink)
dsfordguy
That's way cheaper than i thought.
How much needs to be milled off?
05-28-2006, 08:21 PM   #4 (permalink)
ou812
usually the thickness of the hex on the stud and the thickness of the plate...some are thicker than others.
05-28-2006, 09:13 PM   #5 (permalink)
dsfordguy
So it's not much material that is removed?
05-29-2006, 11:21 AM   #6 (permalink)
ou812
It's around 3/8 to 7/16 of an inch.
05-29-2006, 11:25 AM   #7 (permalink)
dsfordguy
is that 3/8 to 7/16 of an inch including the two rails on the sides used for the pedestal mount rockers or is it 3/8 to 7/16 of an inch after removing those rails?
1972 Torino 351c
<font size=-1>[ This Message was edited by: dsfordguy on 5/30/06 2:25am ]</font>
05-29-2006, 08:27 PM   #8 (permalink)
ou812
Without having a head in front of me I'm not totally sure...but I believe it's after the rails have been milled. Dont hold me to that though...
06-01-2006, 11:51 PM   #9 (permalink)
dsfordguy
been researching on what needs to be machined on the heads. After milling the rails you take it another 0.300" down. Does this sound about right ou812?
06-02-2006, 06:50 AM   #10 (permalink)
ou812
Yes it is about right. Been a while since I did this but it's around 3/8 I believe...but that might be from the very top so .300 sounds like it.
Brian
