06-08-2006, 07:50 AM   #1 (permalink)
rcm600
Rocker stud holes
Do AFR heads have the holes for the rocker studs drilled all the way through into the intake port ? Is this common on aftermarket heads ? Dart claims it won`t affect airflow, how could it not ?[img]/forums/images/smiles/icon_lame.gif[/img]
<font size=-1>[ This Message was edited by: rcm600 on 6/9/06 12:06am ]</font>
rcm600 is offline   Reply With Quote
06-08-2006, 06:10 PM   #2 (permalink)
ou812
Rocker stud holes
If the stud is flush with the roof when installed, it wont affect airflow. If it protrudes some then it will. I always check that the grind the bottoms of the studs or bolts (shaft rockers) so they are flush when torqued.
Also use a sealer so you dont get any oil seeping into the port.
Brian
ou812 is online now   Reply With Quote
06-09-2006, 04:56 AM   #3 (permalink)
rcm600
Rocker stud holes
Thanks Brian, I`ll relax now[img]/forums/images/smiles/icon_bow.gif[/img]
