EA 3.0 was a huge factor in my engine buildup. If nothing else, it gives you some insight on how various variables affect an engine. It predicted my engine nearly right on. I'm using it to predict gains from improvements i'm in the process of making.
The bad thing about desktop dyno's is that they can be very good if your entering correct data or they can be very bad if your entering incorrect data. IOW, you really need to learn to use it and double check your input. EA 3.0 makes fewer assumptions that desktop dyno...it requires more input. Therefore, a better chance of being accurate ond conversely a higher chance of being way off.
Tracy Blackford: Corona, Ca
'65 FB Mustang 331, 282S cam, ported 351W heads. T5z, 3.50 9" posi.
346
RWHP@6400 on a warm spring day (335 RWHP SAE corr.)
<font size=-1>[ This Message was edited by: blkfrd on 11/5/06 4:20am ]</font>
