09-13-2006, 08:40 AM   #1 (permalink)
XDESP
Best shape carbide burrs for porting?
Whats the best shape for porting that you have used?
Eg round nose tree, flame,cylindrical shape ect?
Cast and alloy....
XDESP is offline   Reply With Quote
09-13-2006, 05:42 PM   #2 (permalink)
ou812
I use EGG shape for about 99% of all porting. I use a 3/8 egg, 1/2 egg and 5/8 egg for both aluminum and cast iron.
Brian
09-18-2006, 10:25 AM   #3 (permalink)
marzz22
I've used Flame shape with round tip, Cylinder shape with round tip and Flame shape with pointed tip. I ordered my set from http://www.dearbornclassics.com I used this set to port 2V Cleveland and 2V Aussie heads. I believe you will be doing the same mate...
"Long Live the Cleveland"
<font size=-1>[ This Message was edited by: marzz22 on 9/19/06 1:26am ]</font>
marzz22 is offline   Reply With Quote
10-08-2006, 04:48 AM   #4 (permalink)
PaulS1950
I use pear shaped tips in 1/4", 3/8", and 1/2". I do the final blending with silicon carbide stones.
When using carbide burrs on aluminum use parafin wax to coat the burr. That will keep the burr from loading with aluminum and cut down on the cleanup time.
11-30-2006, 04:24 PM   #5 (permalink)
Mosse
I prefer sylinder-shape with ball halves, for aluminum.
Mosse is offline   Reply With Quote
03-26-2008, 11:26 AM   #6 (permalink)
rjsupply
Re: Best shape carbide burrs for porting?
For a full line of American Manufactured Carbide Burrs, check out this website:
RJ Tool & Supply - CARBIDE BURS - Cylindrical, Cylindrical End Cut, Cylindrical Ball Nose, Ball Shape, Egg Shape, Round Nose Tree, Pointed Tree, Flame Shape, 60 Degree Included Angle, 90 Degree Included Angle, 14 Degree Cone Radius End, Pointed Cone,
rjsupply is offline   Reply With Quote
03-26-2008, 03:59 PM   #7 (permalink)
PSIG
For port matching and bowl work, I use long-cut smaller diameter round-nosed cylinders for 80% of it. The blending angles are much easier to control as well as surface waviness. Final blending is a third the effort than when using a curved-shape cutter (egg, flame, etc.). In the bowls, I use the RN-CYL again and ball-end cutters for the bowl radius and back cutting of the guide radius. If all I had was a long length-of-cut RN-CYL (as long as I could get) and a couple small balls and maybe one small egg I'd be okay. If I'm doing full runner porting I'll use many different cutters from the box. That's a different ballgame. Chambers get the same tools except the RN-CYL is larger diameter.
Opinions you didn't ask for but may help: Use two hands and hug the tool for stability when possible, moving your whole body to move the tool with light pressure. Use lower tool and travel speeds to avoid hopping, skipping and waviness and light pressure to let the cutter do the work without gouging or grooving. Pretend you're a CNC mill. A head jig is very useful and avoids a lot muscle cramping as well as making blending angles much easier to get accurate. Do a little on each port and go back to the first to do more and repeat. Doing one port all the way ensures different ports. Oh, and less is often more. At the minimum, get a shop vac sucked-up to your valve seat and a sensitive vacuum gauge with a thin tube to probe the runner for sudden pressure changes that need blending. Not removal - just blending. Like the lady said - size doesn't matter, smooth technique does.
FWIW,
David
03-26-2008, 05:49 PM   #8 (permalink)
drinkdrivegoto
I got the ZK3LS set from Matco to do a 2.3 head and a cbr600 head a long time ago. I had no problems whatsoever even with the aluminum motorcycle head. I'm by no means a pro head porter but I am a tech at a dealership and still use this same grinder all the time and occasionaly the bits, I'ts some cheap Cummins grinder I got at a traveling tool sale. I'm going to use the same set to do my 289 heads.
Also I was looking in the catalog today and saw this:
MT2880L
And here's the link to the long shank burr sets. http://matcotools.com/Catalog/toolca...&page=2&#32827
drinkdrivegoto is offline   Reply With Quote
05-24-2008, 09:23 AM   #9 (permalink)
MY TWO STANGS
I like to have all 4 of my die grinders setup with assorted cutters . I like to use short shank cutters as much as I can as there easier to control. I found that there are two many shapes in the port to stay with one shape . For a better finish I will switch a flapper wheel for finishing . I have a Ingersoll , CP ,Jet ,Power fist and a Campbell hausfeld. The Campbell is the only one that i would not recommend to any body .
05-25-2008, 01:23 AM   #10 (permalink)
PaulS1950
How much blending of the bowl are you guys doing?
I was taught - and this was a long time ago - to blend the first 1/2" - 3/4" of the bowl and runner. I decided it was a good idea to cut the A.I. R. lumps out of the Windsor exhaust ports in addition to the port and bowl blending.
Paul
