12-28-2006, 09:09 PM   #1 (permalink)
GT300TD
how bout 429
Anyone have any info on homeporting '68 Tbird heads especially removing exhaust passage 'bumps?
Thanks, GT300TD
GT300TD is offline   Reply With Quote
01-01-2007, 05:33 AM   #2 (permalink)
dacofa
how bout 429
Go to 460ford.com everything you want to know and afraid to ask.
01-01-2007, 11:19 AM   #3 (permalink)
ou812
how bout 429
Dont go too far...there is water above the humps. Grind till there is just a little hump there and move on. Use a tulip type ex. valve that will help keep the turbulence to a minimum. You may have to use a valve intended for another head, just be sure length is right and head size is close. The ex. port stingers work well also...
Brian
01-02-2007, 05:38 AM   #4 (permalink)
dfree383
how bout 429
The mad porter on www.460ford.com will have everything and more !!
01-03-2007, 06:19 AM   #5 (permalink)
64 TBOLT
how bout 429
