01-10-2007, 10:00 PM   #1 (permalink)
archoplites
What Sanding Grit to Finish With?
I curious what would be the best sanding grit to finish with on porting aluminum and iron heads?
archoplites is offline   Reply With Quote
01-14-2007, 12:03 PM   #2 (permalink)
ou812
I finish Iron heads with a stone, grit would be like 80. Aluminum I finish with used 80 grits...more like 70 grit.
Brian
01-15-2007, 11:21 AM   #3 (permalink)
archoplites
Thanks ou812. The 80 grit I have plenty of.
03-12-2007, 05:34 AM   #4 (permalink)
Rimmo
60 grit on intake to stop fuel droping out and 340 grit on exhaust port to help stop carbon build-up, this is from another forum and others here may know better, not my personal experience but is what I'll be trying. hope this helps.
Rimmo is offline   Reply With Quote
