03-23-2007, 11:33 AM   #1 (permalink)
dbiscayne
went a little too far, gotta fix?
guess I over did it just a little on the porting- so now I gotta fix this. These are the aluminum Ford GT-40X heads. Removed some material around the pushrod holes, everything was fine till I went over the area lightly sanding by hand for some fine tuning and noticed a tiny scratch going through the port into the pushrod hole.
Now I really don't think this is entirely my fault, it happened right at the seam/middle of the wall adjacent to the pushrod hole. If you've ever seen the inside of a GT-40X port you'd know the finish is pretty crappy, along the length of the middle of the vertical walls is a seam with lots of casting mess, I think what happened is there was always a void in the aluminum and I hit it. It's about 1/10" long and only as wide as a scratch.
What would be the best way to fix it? I was told by the local speed shop/machine shop they could get it right with epoxy, does that sound legit?
thanks
dbiscayne is offline   Reply With Quote
03-23-2007, 07:01 PM   #2 (permalink)
ujt389
I have heard of guys putting brass tubing in kept there with epoxy when that happens.
03-23-2007, 11:55 PM   #3 (permalink)
scottford351
K&S sells thinwall tubing.
It an be found a good hobbie shops.
You may need to slightly ream/ drill the pushrod hole to come out with a good tight fit.
I have done several Edelbrock heads.
I slightly heated the heads and used a large bolt through the sleeve as a driver and pressed them in with a air hammer set down really low. Works great
scottford351 is offline   Reply With Quote
03-24-2007, 12:30 AM   #4 (permalink)
393Clevor
http://www.diyporting.com/Sleeves.html
03-24-2007, 08:56 AM   #5 (permalink)
dbiscayne
great I think I can handle that- only problem is the GT-40X heads have oval pushrod holes but I think I can get something to work.
03-24-2007, 05:55 PM   #6 (permalink)
dbiscayne
Used a piece of 17/32" brass tubing, squeezed it in a vise a little to make it oval and it fit just about perfect. That and some epoxy and it looks good to go.
