06-05-2007, 10:33 PM   #1 (permalink)
sleeperstang
Valve Guide Removal? Necessary?
I've noticed that most of the porting pictures show the heads without the valve guides installed. Is this absolutely required? I have a pair that I bought that has new valve guides installed. They are 351W heads and I've done a good bit of work so far with the valve guides in the head. Any suggestions on how to proceed? If I do need to remove them, what's the best way about going about it and can it be done without damaging the valve guides I have now?
sleeperstang is offline   Reply With Quote
06-08-2007, 01:26 PM   #2 (permalink)
blkfrd
It will be very difficult to port those heads without removing the guides unless you want to make them flush with the port. A machine shop should be able to press them out for you for little money...only thing I don't know is if they can be re-used once pressed out.
My first go around with the DOOEs that I ported were done with the old guides and the new guides were then put in and were trimmed down to be flush with the port. When I wiped a few bearings and had to rebuild last year, I found several guides that had .005 or .006 clearance...they had really worn in only 3500 miles. The shop that re-did my heads said the guides were too short so now I have about 3/16" of the guide protruding out into the port with beveled ends. Some would say I need even more guide length than that. One consolation is that my 26986 beehives have less spring pressure than the old 972s so the force on the guides will be a tad less. Of course rocker geometry plays a big role in all this too.
Tracy Blackford: Corona, Ca
<font size=-1>[ This Message was edited by: blkfrd on 6/9/07 4:27am ]</font>
06-08-2007, 07:39 PM   #3 (permalink)
ou812
Are you asking if you should port the heads and then install the guides, or completely remove the guide boss to help flow?
06-08-2007, 09:15 PM   #4 (permalink)
sleeperstang
I'm asking if it is necessary to have the valve guides removed to achieve a good port job? Or, would it be fine for me to continue porting the heads with the valve guides installed and still achieve good results?
06-09-2007, 12:13 AM   #5 (permalink)
It's NOT totally necesasry to remove the guides for a good port job.
You SHOULDN'T re-use the guides once taken out. and we don't Press them out. We Hammer them out. You would snap the head in two before pressing a guide out with direct constant pressure.
FE
06-09-2007, 09:19 AM   #6 (permalink)
sleeperstang
Great! Thanks for the responses guys, now I can go and grind in peace.
