07-21-2007, 08:24 AM   #1 (permalink)
butch86
pushrod pinch.
Would you get any GAIN if you were to move the pushrod pinch wall in and sleeving them with a brass tube on a set of e7's? This would help a straighter shot to the valve, id just have to keep an eye on taper to try and help keep some sort of velocity up.
Whats your thoughts and opinions ? YEH OR NAY ? This is using the stock valve sizes. im thinking it should help gain some flow , but im not sure with the stock valves could handle it. Im thinking perhaps jumping up to 1.9-1.6 valves.
This is on a n20 motor..
[SIGPIC][/SIGPIC]
butch86 is offline   Reply With Quote
07-23-2007, 12:31 PM   #2 (permalink)
TALONS
Re: pushrod pinch.
Hello sir
yes..I have done this. I drilled mine out first( 5/8). Then ported - you can put a 5/8 wood dowl in there while you flow testing etc until you get done with the port. Dont make a big hole - remeber there are strong pulses in the intake track. Also make sure you deburr and SOFTEN the edges. If the tube pulses - you dont want it to be moving on a sharp edge.
Jim
TALONS is offline   Reply With Quote
07-24-2007, 05:37 PM   #3 (permalink)
ou812
Re: pushrod pinch.
Personally, for a spray application, I doubt you'd see any gains. Figure .100 below your actual lift at the valve, and then flow the head on a bore size closest to what you will use.
Now check the air speed with a pitot tube at the pushrod pinch at the .100 below actual lift and see what you get. Shoot for 300-325fps.
If it's higher than that, then you may see a small gain in performance, probably when your not spraying.
On a nitrous engine, the camshaft and overall flow of both intake and exhaust ports is alot more critical.
Brian
www.immengines.com
08-08-2007, 12:42 PM   #4 (permalink)
ChicoB
Re: pushrod pinch.
Check out diyPorting.com . This site specializes in the E7.
Pushrod length? 73FOMO All Ford Techboard 2 11-17-2006 02:17 AM
429 pushrod Help PSmith7792 Truck Forum 0 03-17-2006 04:00 PM
5.0 Pushrod 89Trooper All Ford Techboard 2 02-11-2004 12:57 PM
Pinch Me - No Don\'t! HankyJ The Garage 7 10-27-2003 07:42 PM
429/460, which pushrod to buy!!!! XolieX All Ford Techboard 11 10-12-2003 12:48 PM
