10-03-2007, 09:32 AM   #1 (permalink)
mentalbreakdow
4 banger dual plug heads
anyone know or know where to find the flow numbers on stock dual plug 2.3 heads. After I get done with the body work and the interior i'm pulling the head to port it, also to do a few more mods while I port the heads. Thanks for any info.
mentalbreakdow is offline   Reply With Quote
10-03-2007, 07:37 PM   #2 (permalink)
mavman
Re: 4 banger dual plug heads
.050"-30.0
.100"-58.0
.150"-86.7
.200"-110.7
.250"-130.3
.300"-143.3
.350"-153.1
.400"-158.9
.450"-164.1
.500"-166.8
.550"-166.8
.600"-170.2
Found this over at turboford.net. There are lots of great threads reguarding the DP head flow. The turbo D port head flows better...but 99% of them are cracked (including mine but it still runs fine). Porting should open the intake flow up to about 210 CFM and a good valvejob should get you 10-15 more CFM. The D port turbo head is good for ~250 CFM on the intake side with a max effort port and valve job. Not bad for a little 2.3 head....
10-03-2007, 07:57 PM   #3 (permalink)
ou812
I've got some stock and ported #'s...but they are at work. I'll post them tomorrow night. Did a bunch a few years ago for some dirt track teams.
Brian
10-05-2007, 05:42 AM   #4 (permalink)
mentalbreakdow
hmm so some ported heads and a well planned out stroked 2.3 should be able to hit 200 hp mark.....haha modifications so far include short throw shifter from mgw, and a piece of pvc pipe with silicon charge air couplers from a isuzu diesel in place of the air muffler, and made a setup to bypass power steering.....coming soon elimination of the exhaust side plugs and coil, completly removing power steering.
10-05-2007, 11:52 AM   #5 (permalink)
ou812
Here's my ported #'s
lift Int. Ex.
.100 54 48
.200 115 90
.300 156 113
.400 179 129
.500 187 137
Brian
10-24-2007, 08:17 PM   #6 (permalink)
mavman
Just thought I'd revive this thread. apparently, the DP head is the hot ticket, according to this post:
TurboFord.net Forums: Dual Plug believers come inside....
I know where there are a few of these heads, one is cracked beyond using and might be a candidate for me to learn with.
10-29-2007, 07:37 PM   #7 (permalink)
trashline
is this going into a n/a 2.3 motor? then I would stick with the higher compression head vs the D port style head. which has IIRC 8.5/1. The N/A 2.3 non D port is 9/1. Not sure on the Dual plug head though.
02-22-2008, 09:48 AM   #8 (permalink)
TurboT-Bird
boport in that thread from turboford did a great job with the dp head.
Amsoil Dealer
www.NotNormalMotorsports.com
www.TurboT-Bird.com
TurboT-Bird is offline   Reply With Quote
What plug in gt40p heads 56chevyguy Late Model EFI Techboard 5 07-10-2007 07:07 PM
66 ford heads? How do you plug the hole for the air tubes 66falcon All Ford Techboard 7 10-17-2005 01:55 PM
Dual Quads w/ stock heads and cam Questions topdeadcenter All Ford Techboard 9 01-03-2005 10:43 PM
How to machine heads for dual springs? Gent All Ford Techboard 0 10-20-2003 10:35 PM
dual exhaust/headers for 351 C mustang w.2v heads? DaveZee All Ford Techboard 6 01-08-2003 01:19 PM
Lakewood
Holley
