11-02-2007, 05:45 AM   #1 (permalink)
retroFiveOH
Porting potential of GT40 Vs early 351W heads
I've got a set of early 351W heads that look to be in good shape that I was planning on porting and having them rebuilt. I think I found a complete 96 Explorer 5.0L that's in great shape, so I was wondering about how the GT40s compare to the 351W heads as far as performance after they've been ported? I was under the impression that all iron SBF heads came out about the same when ported?
--Kyle
'66 Mustang Coupe 289/C4 HiPo cam...not in progress
'66 Mustang Coupe Explorer 5.0L, looking for a T5
retroFiveOH is offline   Reply With Quote
11-02-2007, 06:56 AM   #2 (permalink)
ou812
Re: Porting potential of GT40 Vs early 351W heads
The GT 40's will make more power. How much depends on your build but typiacally it's around 20-30 more HP.
It's not hard to improve upon the stock sb stuff...
www.immengines.com
ou812 is online now   Reply With Quote
11-02-2007, 11:20 AM   #3 (permalink)
blkfrd
Are you talking stock form? I would be surprised there would be much of a difference between the two after porting. I believe the GT-40s referred to here are the GT-40Ps and the 351w heads are either '69 or '70 C90E or D00E heads.
I correct myself, I just read the Ps didn't come along until 1997 and your heads are coming out of a 96 Explorer.
Found an article that has some comparison data for stock GT-40 and GT-40Ps here under "Articles"
StangPro.com
Here is a site that has comparison data for ported GT-40s and '70 351w heads (DOOE)
Cast Iron Heads
Tracy Blackford: Anaheim Hills, Ca
Porting 351W heads verstappen Home Porting Cylinder Heads 4 11-01-2006 01:57 PM
Do GT40 valves fit 351W heads? johnebli Late Model EFI Techboard 4 01-31-2004 10:24 AM
? about using GT40 bolt down rocker heads on an early smallblock? DesertSnake All Ford Techboard 1 10-14-2002 12:43 AM
porting 351W heads for 289 67ragtop All Ford Techboard 3 01-21-2002 08:23 AM
porting 351w heads MGT351 All Ford Techboard 2 01-18-2002 07:39 PM
