12-16-2007, 11:49 AM   #1 (permalink)
ndmus88gteng
lunati .500 lift cam and heads
Hi, I have a stock 302 91, w/70,000 miles on it stock, I have a lunati .500 lift cam I want to install, what type heads, Yes on a budget, should I get to get the most power out of this cam, not interested in the h.p. # game, just want good old seat of the pants power, I would be able to up-grade injectors/intake, if needed later, will be fuel injected, there are too many heads out there for me to be guessing what would work, or not, maybe some of you guys could help a fellow out THanxs
ndmus88gteng is offline   Reply With Quote
12-16-2007, 02:47 PM   #2 (permalink)
ou812
Re: lunati .500 lift cam and heads
List the specs of the cam, and what type (hyd, hyd roller, etc...)
Looks like either some rhs cast iron heads or maybe some TF twisted wedge heads.
Brian
www.immengines.com
12-17-2007, 04:22 PM   #3 (permalink)
ndmus88gteng
hi, its a lunati, .500 lift on intake .510 lift on exh,duration @.050=218 in 226ex, advertised 284 in 292ex lobe seperation 112 in opens 1 degree btdc closes 37 abdc ex opens 49 bbdc closes -3atdc application is for 351 w , HEY gear heads sorry bout the wrong forum, jus needin some help THanxs
12-18-2007, 06:16 AM   #4 (permalink)
ou812
With that cam I would go with the TF heads. Or AFR 185's.
www.immengines.com
12-18-2007, 02:14 PM   #5 (permalink)
ndmus88gteng
hi, heard a lot about the AFR 185, and 165, I have a stock eng,, is this cam and 185's a lil too much for the stock bottom end,,,, if not that sounds pretty good to me, those 185's are real expensive, ,,, any idea of h.p. with the stock (19) inj.,,,, or should I go ahead and up-grade to 24lb, and m.air meter? A guy on ebay had 1970 doosumthing 351 w heads w/chevy 196/160 valves and exh. ported (exh. HUMP),,,, all rebuilt, shipped for about 650, said he runs a mach. shop, they looked real good to me, but I dont know for sure, so i didnt get them, thanxs for the info
12-18-2007, 02:54 PM   #6 (permalink)
dfree383
Ford GT-40X Aluminums, Edelbrock RPM's, AFR 165's, Brodix 5.0 ST are all good choices
12-19-2007, 02:16 PM   #7 (permalink)
ndmus88gteng
what do you guys think of the 1970 dooe 1.94 and 1.64 (ithink) about for the valves, iron heads w/ported exh, side, chevy valves,about 650 shipped, he put the bigger valves in, and rebuilt and ported them thanxs
12-19-2007, 02:30 PM   #8 (permalink)
dfree383
Spend the Extra $350 on a good set of aftermarket Aluminum ones, they are light years ahead of the old factory castings.
You can get Edelbrocks and GT-40x heads new in the box for about $1000.
GT40 heads off of 96 explorer...how much lift will they take? dablack All Ford Techboard 8 02-01-2006 11:27 AM
how much lift/duration can i run with AFR-205 heads on 351W kapnk All Ford Techboard 13 01-09-2006 10:44 AM
To lift or not to lift front ride height of the 65??? KidPoboy All Ford Techboard 12 10-12-2004 02:56 PM
What durqation and lift will I need to run over 350 RWHp with a 302 and victor jr heads?? nitroponynj Late Model EFI Techboard 2 09-15-2003 01:17 AM
Lunati Cam BlindMuleL227 All Ford Techboard 5 04-27-2003 11:31 PM
