12-26-2007, 01:56 PM   #1 (permalink)
buzz1963
D0OE 1st timer - questions
I'm doing my first porting job on a set of D0OE/351 heads. I have two quarstions
1. What is the second exhaust passage exiting the second cylinder of each head? It looks like it goes to the intake side of the manifold. I'm not sure what I should do with it with respect to porting.
2. I want to install 1.94/1.60 valves but an not sure what to buy. Some speed catalogues list 1.94/1.60 in the Chevy section and also under the Ford section with a note that the valves are .050 longer. Should I just but the standard length Chevy valves? I'm planning on using roller tip rail type rocker arms.
I'd appreciate any words of experience on this thanks.
buzz1963 is offline   Reply With Quote
12-26-2007, 05:38 PM   #2 (permalink)
lexus
Re: D0OE 1st timer - questions
standard length will be the one they are only 1000ths longer than ford vavles and work fine
lexus is offline   Reply With Quote
12-28-2007, 11:28 PM   #3 (permalink)
TurboT-Bird
I belive the port you are wondering about is egr, not sure though
Amsoil Dealer
www.NotNormalMotorsports.com
www.TurboT-Bird.com
TurboT-Bird is offline   Reply With Quote
01-03-2008, 09:20 AM   #4 (permalink)
blkfrd
Those passages are for heating the intake manifold. Performance manifolds and gaskets block these passages.
Tracy Blackford: Anaheim Hills, Ca
Another Talented Old Timer Passes On Calspec The Garage 3 10-08-2007 08:07 PM
First Timer Questions bprigge C4 Transmissions 13 04-11-2007 05:26 AM
old timer gASS. BobsSleeper The Garage 4 02-01-2005 05:57 PM
first timer NoLongerHere2 Home Porting Cylinder Heads 3 12-13-2004 06:08 AM
Help update an Old Timer 392Bird All Ford Techboard 10 03-22-2004 10:08 AM
