01-18-2008, 07:40 AM   #1 (permalink)
wrenchhead627
Does anyone have flow numbers for tfs high port
I need the flow numbers for the Trick Flow High Port CNC 225 heads if anyone has them.
wrenchhead627 is offline   Reply With Quote
01-18-2008, 07:53 AM   #2 (permalink)
Mikes66
Re: Does anyone have flow numbers for tfs high port
Every Head's performance airflow numbers are listed at this link.
This is a great link.
Ford Head Flow Data and Specs
[SIGPIC][/SIGPIC]
01-18-2008, 08:32 PM   #3 (permalink)
mbrooks
here is some pretty good info.
Unltimate Guide to 5.0 Cylnder Heads, Part 7
mbrooks is offline   Reply With Quote
03-09-2008, 12:53 PM   #4 (permalink)
tonys10sec306
325-330
[img]http://www.fordmuscle.com/readerscars/showpic.php?id=371[/img]
Trick Flow High Port \"Street Heats\" toploader All Ford Techboard 3 04-13-2006 10:43 PM
Hand Ported S.B. Ford Trick Flow pics and flow numbers shadydell Home Porting Cylinder Heads 10 03-23-2006 06:37 PM
Quality Of Trick Flow \"High Port\" Cylinder Heads? GregS All Ford Techboard 5 12-13-2004 10:02 PM
good SBF iron head to port, wanting flow for high revs fastbigblockford Home Porting Cylinder Heads 3 09-02-2004 10:38 PM
Trick Flow intake manifold flow numbers ibpluto Late Model EFI Techboard 4 03-26-2003 11:42 AM
Holley
