02-13-2008, 04:00 PM   #1 (permalink)
Rcode427
Check out these fe heads
The heads are from 1962 era fes . A B head is probably a 406 ? Anyway I am wandering if the way they have made ports so large will they truely be worth the time to buy and if they would out proform a 6090-N scj head ? They have the large valves installed .
eBay Motors: FE RACE CYLINDER HEADS Ford Galaxie 390 406 428 427 (item 330211708035 end time Feb-22-08 18:57:28 PST)
02-13-2008, 04:32 PM   #2 (permalink)
dfree383
Re: Check out these fe heads
Looks like a hack job to me, you need to watch velocity and port sizing / Valve sizing to get a head to perform. BIGGER DON'T MEAN BETTER.
I be curious to see the actual flow number and see how lazy the are.
02-14-2008, 06:05 PM   #3 (permalink)
mmuenchow
[quote=dfree383;1390825]Looks like a hack job to me, you need to watch velocity and port sizing / Valve sizing to get a head to perform. BIGGER DON'T MEAN BETTER.
I be curious to see the actual flow number and see how lazy the are.[/QUOTE
I have ported 3 sets of fe heads.c0 c2 c3 by far the best thinf you can do is exhaust bowel work and a good 3 angle valve job. Large ports kill torque,preformer rpm intake and a good cam will wake up your fe
mmuenchow is offline   Reply With Quote
02-14-2008, 10:25 PM   #4 (permalink)
Yeah... Those heads look to need about 5,500 rpms just to begin making power...
02-18-2008, 01:58 PM   #5 (permalink)
blkfrd
What bothers me is that they, from all visual indications, really lowered the short side floor...this can totally kill flow. Raising the roof...yes. Lowering the floor...no.
Tracy Blackford: Corona, Ca
02-19-2008, 12:20 AM   #6 (permalink)
PaulS1950
It looks to me like they started with 390 "high-rise" heads and butchered them to the point where they hit water jackets. Then they tried to repair them by having them welded up. I wouldn't touch them. They look like junk.
Paul
Been a while - check out the new look!! ScreaminC Falcon Pages 8 05-15-2006 10:55 PM
Check out the new 351 2V Aussie heads...aluminum! Humphrey351 All Ford Techboard 6 10-08-2003 01:05 AM
Check this out 393Clevor The Garage 1 02-07-2003 07:35 PM
CHECK THIS OUT..... Ponygirl67 The Garage 7 03-02-2002 02:00 PM
Click My Cars icon and check out video of Green Machine II beating a new Vette- Heads Up! FasterDamnit! The Garage 12 01-13-2002 10:50 PM
Holley
