03-30-2008, 09:57 AM   #1 (permalink)
drinkdrivegoto
found a nice die grinder...$8
I went to harbor freight to pick up a grinder with a composite body, im getting tired of my hand freezing off while im porting these 289 heads. i found a composite bodied 1/4" for $8 but I wont be back at the shop to try it till tomorrow. They also had the Central Pnumatic Professional for $15. The safety on the red one has a horrible design, but it was super easy to pop off.
drinkdrivegoto is offline   Reply With Quote
04-19-2008, 02:14 AM   #2 (permalink)
PaulS1950
Re: found a nice die grinder...$8
Those grinders are not very strong. For someone who doesn't do much with it you will be fine. The bearings are weak and the bodies flex. Chech to see how much the collet is off-center before you do much with it. Treat it nice and it might be fine but if you try to do too much or do it too fast you are going to be reminded why it says, "Wear safety glasses when using". It might be a good idea to get a good pair of heavy leather gloves to wear while you are using it.
Paul
Die Grinder Cutters/Bits ?? tdf_46 Home Porting Cylinder Heads 19 04-10-2008 11:33 AM
Lay That Grinder Down Boy! JDKRUZER1 Falcon Pages 2 01-03-2008 09:07 AM
8,000 rpm grinder... Help... imported_RoadRunna Home Porting Cylinder Heads 8 09-04-2007 02:03 AM
Finally found a nice 63 RobFatH Fairlane Pages 20 04-03-2007 07:22 PM
Found nice pics from german fords Robbi The Garage 0 06-19-2002 06:03 PM
