04-18-2008, 02:46 PM   #11 (permalink)
tang302
Re: porting D80E head need advice
In Argentina. Just a few SB were imported in 1980 Ranger´s & Bronco´s.
Shipment cost is very expensive to us.
tang302 is offline   Reply With Quote
04-19-2008, 02:08 AM   #12 (permalink)
PaulS1950
Try the heads that you have. The worst that can happen is you get a little water in the exhaust. It will make lots of steam if they crack but it won't hurt anything. Then you can find a new set of heads when you need them.
I would be more concerned with those small chambers. Have you calculated the compression? If I put 53 cc heads on my 351 it would raise my compression to over 10.5 : 1. We can't buy gas that would run in my engine - the way it is configured - with 10.5 : 1 compression.
Paul
04-19-2008, 12:51 PM   #13 (permalink)
tang302
The D8OE chambers are 69 cc. I´ve got the block rebored at 4.030" and the piston (Speed Pro L2488 F30) are over deck height at 0.003".
With Fel Pro 1011, the quench height is 0,035". Then, compression rate 9:1
The original 1968 heads had 63 cc, rated 9:1 compression, with stoch deck height and stock dished pistons.
Head porting fahlberg All Ford Techboard 13 09-20-2006 10:20 PM
head porting help jrr All Ford Techboard 1 01-24-2006 12:12 PM
head porting dave377 Home Porting Cylinder Heads 0 10-05-2003 11:34 AM
head porting stinger All Ford Techboard 13 07-23-2003 09:36 PM
POTENTIAL OF D80E HEADS??? BBCFORD All Ford Techboard 10 03-28-2003 08:28 PM
