04-23-2008, 07:14 PM   #1 (permalink)
crober55
question on E7TE headas
I recently bought a set of rebuilt E7's from Allied Motorsports in Atlanta to replace my old e5ae heads. Looks like the work is excellent with new guides, posilock valve seals, five angle valve job and resurfaced. I am going to grind out the thermactor bumps to improve flow, but if I port match the exhaust ports, will I hurt the velocity? My stock exhaust manifolds are also plugged up with bumps on the inside of the sides to where I can,t get my finger very far in. My engine is a 86 351 HO out of a F-150 with very few miles on it.It has a Comp Cams extreme 4x4 cam with 262-270 deg. .493-.512 lift 111deg LSA.
What I'm trying to say is will I hurt the performance by porting out the ex ports and adding a set of Hooker full length headers? Also how much better is an aftermarket aluminum manifold over the stock iron one? So whaddya say?
Thanks from Bud in Arizona
crober55 is offline   Reply With Quote
04-23-2008, 08:10 PM   #2 (permalink)
notched306
Re: question on E7TE headas
the E7 heads really come alive with the exhaust side worked.
turbo notch,fully built 306 by yours trully,running on E85
notched306 is offline   Reply With Quote
04-25-2008, 06:06 PM   #3 (permalink)
iwantmore
Re: question on E7TE heads
I would be careful at the port. Most improvement is made in the area under the valve and get rid of the hump. Search home port E7
E7TE heads cc DCOBRANOS All Ford Techboard 4 03-08-2008 10:54 AM
E7TE-T vs E7TE-PA biglaw22 All Ford Techboard 0 10-27-2007 09:02 AM
How much of an improvement are E7TE\'s? Fiveoh All Ford Techboard 8 08-12-2005 07:39 AM
E7TE images gerzen All Ford Techboard 7 02-14-2004 12:34 AM
E7TE Heads bprigge All Ford Techboard 3 02-23-2002 11:21 PM
