05-19-2008, 04:58 PM   #11 (permalink)
BaronVonOttoma
Re: Home ported D0OE 351W head flow numbers
Thanks Joe, they were going to go back on the 351W from whence they came. I ended up buying a set of aluminum heads so these will trickle down to a 302 with D8 heads. I'm hoping I'll actually pick up a point or so. I'll confirm the chamber size on the old heads.
BaronVonOttoma is offline   Reply With Quote
Hand Ported S.B. Ford Trick Flow pics and flow numbers shadydell Home Porting Cylinder Heads 10 03-23-2006 06:37 PM
How much H.P. from home ported 351w heads.......... BOB3299 All Ford Techboard 8 06-06-2005 09:34 PM
D0OE-351W head cut up after some port work 393Clevor Home Porting Cylinder Heads 2 03-12-2004 06:31 PM
Port Volume (Home Ported D0OE) CWToyota All Ford Techboard 14 11-22-2003 09:12 AM
Flow numbers on Ported Edelbrook Performer Heads ibpluto Late Model EFI Techboard 1 05-11-2003 05:56 PM
Lakewood
