08-09-2008, 04:53 PM   #11 (permalink)
Re: is that a cleveland head?
Originally Posted by MY TWO STANGS View Post
It is not hard you can drive a car into the port of a 4 barrol cleveland .
ooooooooh... Like a boss 302 head as compared to a 289 head then
08-10-2008, 03:12 PM   #12 (permalink)
dbu8554
boss 302 head is a cleveland head
dbu8554 is online now   Reply With Quote
08-10-2008, 03:15 PM   #13 (permalink)
DanH
a Boss302 is a Windsor head, there are differences
08-10-2008, 05:22 PM   #14 (permalink)
MY TWO STANGS
The Boss 302 head is a 351 Cleveland head that was modified by ford to run on a 302 block . All though the Boss 302 engine was released first these heads were intended to be 351 Cleveland heads . This came about because the 302 tunnel port trans/am engine was a expensive flop. Ford needed an engine to compete with the Z28 camaro for the 1969 race season .
08-17-2008, 06:32 PM   #15 (permalink)
seefour
thats a 2v port , George Strigle at Clay Smith cams told me once that he had a customer that had a 4v head on a sand rail , always running at the back mof the pack. he suggested to his customer to install a nicely ported 2v head on his motor, amazing thing happend...nobody in his class could beat him afterwards. A good ported 2v head can flow 260-270 cfm.
seefour is offline   Reply With Quote
08-18-2008, 09:21 AM   #16 (permalink)
Hager
thats a cleveland head. 2v.
Hager is offline   Reply With Quote
08-20-2008, 11:48 PM   #17 (permalink)
MY TWO STANGS
A well ported set of 351 4V heads can see a flow number close to 400CFM . I have been racing Cleveland's since 1970 , I have never seen 2v Cleveland in my class that was faster than MY 4v engines .
08-21-2008, 12:13 AM   #18 (permalink)
PaulS1950
The Boss 302 head was produced before the Cleveland was so the Cleveland head is a Boss head modified to make it unusable on any other small block Ford - only it can be modified and the after-market guys made some manifolds for the swap.
Paul
08-21-2008, 03:54 AM   #19 (permalink)
MY TWO STANGS
The Boss head was released before the Cleveland but, the Cleveland was in development for over a year , ford realised that when the tunnel port was reved to the point were it devepoped its power it would not live . ford lost the chanpionship in 68 .They needed Better ahead for there engine and the Cleveland head was the easiest and cheapest way to go . I am pretty sure it was Bud Moore that decided to try the Cleveland head on the tunnel port block . Ford had been working on the Cleveland head before the Windsor was put into cars but it had some flaws that had to be worked out . Ford had BS'ed there way through the 68 season with out having a production tunnel port and the trans /am sanctioning body demanded 500 cars built for the 1969 race season , or the mustangs would have to revert back to the old 289 . That is why the 302 boss engine was installed in cars before the Cleveland was realeased.
08-22-2008, 07:24 PM   #20 (permalink)
70Cougar
I agree on the 2bbl cleveland head ID. Here is a pic I took some time back. I like the answer you gave about the reason the boss 302 heads are so much like the clevelands.
John
70Cougar is offline   Reply With Quote
how much are 4bbl cleveland head worth? gtnrb71 All Ford Techboard 0 04-10-2008 10:21 PM
Cleveland 4v head question gchero351 All Ford Techboard 13 04-07-2006 03:24 PM
Cleveland head cast numbers PEPPER All Ford Techboard 4 05-25-2004 01:19 AM
Aussie Cleveland 2v vs. 4v head gaskets SteeLDawN All Ford Techboard 9 11-21-2003 12:47 AM
Cleveland Head Mods ScreaminC All Ford Techboard 4 02-23-2003 12:28 PM
